01-05-2009, 03:09 AM | #1 |
DDOV
Wide tires
what is the widest tire you can fit under a stepside swb? im going to cut some out of the beds inside, but i dont want to do any frame or trailing arm work
If you don't like the way I drive, stay off the sidewalk http://67-72chevytrucks.com/vboard/s...d.php?t=317070 The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself? |
01-05-2009, 04:07 AM | #2 |
Re: Wide tires
search for the build thread of that yellow pro-street... I think he probably has the widest tires I've seen under a stepper.
01-05-2009, 04:15 AM | #3 |
DDOV
Re: Wide tires
good idea.. thanks
01-05-2009, 04:29 AM | #4 | |
Re: Wide tires
no problem... I was curious myself so I did a little searchin and found this:
http://67-72chevytrucks.com/vboard/s...d.php?t=321173 Quote:
He took a lot out of the beds though. Keep in mind he has mono-leafs in the rear... trailing arms might make things more difficult. Last edited by 19GMC63; 01-05-2009 at 04:32 AM. |
01-05-2009, 08:21 AM | #5 |
Airport Bum
Re: Wide tires
I have seen 14" Sticky Micky's under a fairly stock '65 at "Cruisin the Coast" a few years ago.
It was tubbed naturally. Its all in getting the off set perfect. I was going to do that to mine back in the '90's
1964 Chevrolet C-10 1941 Chevrolet coupe 1962 Thunderbird 1959 Edsel Villager 1963 Skylark |
01-05-2009, 02:23 PM | #6 | |
Re: Wide tires
On my 68 short fleet, I had installed 15x14" steel wheels w/31x18.5 Mickey T's. It required custom back-spaced wheels, larger tubs, & removal of the bumpstop on the outside of the framerail. Pre-67's shouldn't be much different.
01-05-2009, 03:10 PM | #7 |
"Where were you in '62?"
Re: Wide tires
Baby got Back!!!!!!!!!
I want widder Tires on her......but these will do!! I have more pictures here: http://67-72chevytrucks.com/vboard/s...69#post3006169 Modifications Altered Body & Frame The rear end did not need to be narrowed. 1958 Ford Wagon; 3.70 gear 28 spline. Wheelbase 117” Rearend / Ratio 58 Ford Wagon 9” / 3.70:1---->for now. Want a 4.10 gear in her with Detroit Locker. Rear Suspension Mono Leaf Springs, Shocks Gas Rear Brakes 11” Drums Rear Wheel make, size Weld Draglite 15x12 Rear Tire make, size Mickey Thompson 29x15.50-15LT Tube Type Still modding my rear end setup You always can go widder!! But you have to do some modifying like I did or more. If ya got any questions.....just give this ole' boy a hollar!
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 01-05-2009 at 03:31 PM. Reason: Cuz, I wanted to........."Gosh" |
01-05-2009, 05:24 PM | #8 |
DDOV
Re: Wide tires
DAYUMM.. that thing is bad stephen
01-05-2009, 05:35 PM | #9 |
DDOV
Re: Wide tires
looks like it would have traction problems.. i bet you have a hard time gettin out of your own way...
01-05-2009, 06:36 PM | #10 |
Re: Wide tires
Thanks bud,
She doesn't have that many horses for me to wrestler her like the Big Dawgs. . . Mashed on her a couple times and she was dancing all over the road! She's light! Left some white smoke on a couple pansy rice burners a few times. She is dangerous in the rain. Got caught a few times coming to and from a couple local car shows. I gotta work on my steering for one thing. Yank that dag gum steering columb out and put a tilt in her. Got to check on the alignment as well. She was pullin to the right I think. A lot of work to do! Will keep ya updated!
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
