01-05-2009, 07:50 AM | #1 |
Anyone know Bed to frame bolt sizes?
Does anyone know where I can find out the correct size and lengths of the 8 bolts needed to mount my bed to my frame? And I know I need washers, lock washers and nuts. Thanks
If your not living for something, your dieing for nothing... |
01-05-2009, 08:50 AM | #2 |
Under Construction
Re: Anyone know Bed to frame bolt sizes?
I bought my replacement bolts at : www.gmcpauls.com. , as i could only find galvanized local. after i placed the order I saw some zinc coated at Tractor Supply. The size is 5/16 and the length is 4' . this is a carriage bolt.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 01-05-2009 at 08:57 AM. |
01-05-2009, 11:00 AM | #3 |
I went to the local hardware store & got mine. Less than $5 if I remember correct...
01-05-2009, 11:44 AM | #4 |
Under Construction
yep .. hindsight is 20/20 could have saved 10 bucks....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
01-05-2009, 02:14 PM | #5 |
I went to a fastener store and paid 4 bucks for 8 bolts, washers, lock washers and nuts. LMC wants 20 bucks and by the time I factor in the exchange and freight to Canada its way more than that. Thanks guys...you are a godsend as always
01-05-2009, 03:23 PM | #6 |
I belive the correct size for these bolts is 3/8-16 x 4" carriage bolts. I did at one time pull a steel floor bed apart that had 6 of these and 2 7/16" bolts? Go figure.
01-05-2009, 06:28 PM | #7 |
Under Construction
I should have put IIRC then, i was going off memory.... Hopefully the 5/16 work if not i am sure he can exchange for 3/8
01-05-2009, 06:39 PM | #8 |
'71 chevy s.bed/s.side
I just installed mine, they are 3/8" bolts.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
01-05-2009, 07:51 PM | #9 |
When I had my steel floor off, 6 of the originals were 3/8 and 2 were 7/16.
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
01-06-2009, 12:02 AM | #10 |
6 of mine are 3/8s. The front most 2 are 1/2"
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop 70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress |
01-08-2009, 01:16 PM | #11 |
I'm kind of jumping in, but it's related. Does anyone know why the bed mounting washers have the hole offset? There's probably a reason. Also, have any of you used just normal washers with success? Thanks.
01-08-2009, 02:49 PM | #12 |
Under Construction
the only ones i have seen with offset washers are for wood floors.
