spark plug for 72 w/hei
what plug would you guys use for a 72 chevy w/350 and accel hei. the motor is pretty much stock w/edelbrock carb and intake and the new hei. i will be using ac delco plugs.
ASE master tech/machinist
Re: spark plug for 72 w/hei
R45TS for tapered seat heads, (5/8 socket sized) or R45 for the washer seat plugs (13/16 socket size). Set timing to about 6-8 degrees after TDC with advance un hooked and it will run like a singer sewing machine.
![]() Join Date: Jan 2001
Active Member
![]() Join Date: Jul 2007
Firefighter
I have always run AC Delco R44T's, and never had a problem!!!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
Restoration Virgin!
just a thought....if you have aftermarket headers you may want to think about accel shorty spark plugs for clearance!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
I use R45TS gapped at .045" , timing at 12-before in my 402 with HEI and Heddman Elite headers. I don't have any clearance issues and it runs like a top.
Old Skool Club
![]() Join Date: Jun 2001
AC RapidFire....no issues
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Hollister Road Co.
I just converted over from points and have R45ts .050 gap. @15* Idles very smooth. R44ts @.045fouled, R45ts' @ .050 are doing better.
I did indeed, thanks for catching. I feel a bit slow now.
