Old 01-05-2009, 03:14 PM   #1
Jeffvega
73 up motor mount location on '70
I read the FAQ section on the mods required for the '73 up mounts on the '67-'72 frame but I was wondering if it locates the engine in the stock location forward/back as stock. I guess what I mean is if I were to do this would my engine drop back in and connect to the bellhousing of the trans like stock?
1970 GMC LWB ALL STOCK FOR NOW
Jeffvega is offline   Reply With Quote
Old 01-21-2009, 08:00 PM   #2
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: 73 up motor mount location on '70
I have this same question, I want to upgrade to the later style mount, but want to keep the engine in the stock location.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 01-21-2009, 10:38 PM   #3
Jeffvega
now that I've started this project I can see that it moves the motor back about 1.5". I'm going to mach it up and see where to drill new holes
Old 03-20-2009, 12:51 PM   #4
steelhorse
steelhorse's Avatar
Any updates on how it went.
steelhorse is offline   Reply With Quote
Old 04-17-2009, 01:35 AM   #5
westex245
westex245's Avatar
Im really interested in this too, I want the newer mounts but want too see how it turns out.
westex245 is offline   Reply With Quote
Old 01-10-2010, 02:58 AM   #6
68custom396
I used the 73 and later bb mounts on my 68. I put the motor and tranny in together and had the stands bolted to the motor so it would sit in the frame, then i could see where the tranny mount bolts were (due the the greese build up) then i knew the motor was in the right place. drilled new holes in the frame and bolted the stands down
68custom396 is offline   Reply With Quote
