Old 01-05-2009, 04:33 PM   #1
cochino12
It followed me home?
cochino12's Avatar
One ton brake rotor differences
I'm trying to order some drop spindles for my crew cab (which isnt here) and I need to know what size the rotors are? is it a year model issue like 1/2 tons? Or am I going to have to drive a 1/2 hour to where it's stored and pull a wheel off the front to find out which rotors I have?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-05-2009, 04:53 PM   #2
boatpuller
boatpuller's Avatar
Re: One ton brake rotor differences
adam,i can't answer your question.but,i can make it more confusing.i don't think all 1/2 ton got the smaller rotor's.i'm not sure of size's,i think there 1 inch and 1.25 inch.my 1/2 ton had 1.25 the larger.it could have been chevy put those on diesel's also as mine was a diesel.i would think the ton's would have the big rotor.but,i'm not positive.if your not in a big hurry one of the 1 ton boy's will know for sure.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 01-05-2009, 11:27 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Hey Adam. Bolt on a set of ECE's conversion drop spindles. (That's what I was going to use on mine.)
They allow you to install 1/2 ton rotors and calipers without changing balljoints or tie rod ends.
I assume you are going the 1/2 ton route???
Keith
Convert to disc brakes.
Old 01-05-2009, 11:29 PM   #4
lolife99
lolife99's Avatar
Look here:
http://www.earlyclassic.com/catalog....gory=Drop+Kits.
Keith
Old 01-06-2009, 07:30 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've found (through my research for my current dually conversion) that 71-74 uses the smaller brakes and 75 and newer use the larger. Above that though, apparantly there are several different calipers for these larger brakes.
I'm using an 84 truck as a donor and there are three options for the calipers. Same pads and rotors and spindles, just different calipers.
Did any of that help answer the question ?
Old 01-06-2009, 10:54 AM   #6
cochino12
cochino12's Avatar
No I want to keep this one ton but thanks for the link, are you going 1/2 ton because of wheels selection?
I didnt realize everything was the same with the exception of the calipers. I actually called to order spindles and I guess they are all the same and I just read the ad wrong ha ha.
Thanks for the input boatpuller and Tx Firefighter
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-06-2009, 11:11 AM   #7
lolife99
lolife99's Avatar
I'm going 1/2 ton like member OJOE did.
I want the "cushy" ride of a 1/2 ton, and the better selection of drop components. (Some I already have)
Keith
