1970 Daily Driver
Driveline Vibration Issue
What ever happened to "checking it out" when your vehicle made strange sounds or "felt funny"?
Driveline Vibration Issue - Possible Root Cause This guy ran over a mattress and decided to keep going. The ensuing jumble finally whipped around enough to put a tear in the fuel tank and the subsequent lack of fuel is what finally brought this vehicle to its knees. It had still managed to drive 30 more miles decently with a 60lb tangle wrapped around the driveshaft. This genius complained that the vehicle had a "shimmy" when driving it high speeds. This is what the dealership found.............. I dont know why I had to shrink them down so much to get them to upload but I couldn't make them bigger. If any one knows how to size better you can PM me your email and I will send you the pictures in full size to upload. ____________________________________________________________
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
member #16
![]() Join Date: Dec 1999
Re: Driveline Vibration Issue
Change the pics from Bitmap to Jpeg format, then you can post a larger image. 640x480
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
1970 Daily Driver
How do you go about doing that? knowing how to shrink them in paint is an achivement for me
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 01-05-2009 at 05:40 PM. |
