Old 01-05-2009, 10:56 PM   #1
bamaboy
c20 drop... HELP!!!!
i have a 73 c20 that i want to drop. i was hoping for a 4-6 or a 5-7 drop kit but no matter how much i look, i can't find any for my model! do they even make them?
BEST BELIEVE I'M ALWAYS CHEV'N IT
bamaboy is offline   Reply With Quote
Old 01-06-2009, 11:32 AM   #2
royo
royo's Avatar
Re: c20 drop... HELP!!!!
the front will be easy the rear will take some work.you will have to take leafes out and do a lowering shackel. cut your spring 1 coil in front or use half ton stuff
nickle and dime
royo is offline   Reply With Quote
Old 01-07-2009, 10:28 PM   #3
bamaboy
yeah i was just going to do 2'' drop coils and 2'' drop shackles in the front for 4 inches total. but the back was where i was stuck.
Old 01-07-2009, 11:47 PM   #4
royo
royo's Avatar
do the leaf springs measure the same across the top. with half tons early classic ent has drop leaf springs and shackles. or take leafes out of the pack it will,nt haul as much but it will lower it
nickle and dime
Old 01-08-2009, 09:11 PM   #5
cochino12
It followed me home?
cochino12's Avatar
I just ordered 2" shackles and 2" hangers for the back of mine, if I need more I'm just going to pull a leaf spring or two. If you really need the payload throw a set of bags on the rear. You can always make a flip for the rear pretty easy, or I think the 1/2 ton stuff might work?
There are several options for the front, I'm going with 3" spindles (western chassis) and if it's not low enough I'll cut 1/2 coil or buy some drop coils.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-11-2009, 08:32 PM   #6
bamaboy
what do you mean?
Old 01-11-2009, 08:34 PM   #7
royo
royo's Avatar
what do you mean?
ece has a drop kit but they need a measurement of the leaf springs
www.earlyclassic.com
nickle and dime
Old 01-12-2009, 01:30 AM   #8
bamaboy
alrite thanks
