c notch question
okay I am looking at the 3/5 drop kit from Western Chassis and am just curious. Is it absolutely necessary to notch the frame with the 5" flip kit? They sell a 3/5 deluxe kit that includes the c-notch kit for 279.95, or the econo kit for 209.95. Price is not my worry I just need to know if I HAVE to or Highly recommended that i "C" the frame
83' internally ballanced 383 Stroker, 400 turbo 3800 stall , Posi, 750cfm carb, Weind manifold, long tube headers, and a handful of other goodies. Custom billet and woodgrain interior. |
6.0 powered square
Re: c notch question
you can go with out a notch and short bump stops, but I would get a c-notch more axle clearance, and it will allow you to go lower
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#3 | |
It followed me home?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 01-06-2009 at 01:47 AM. |
would i be better off in the long run by going with a spindle+spring combo for the front?
Cruzzzn' Vet
Yes, and you don't need a C-notch with the flip kit
Unless your springs and/or shocks are worn out. It probably won't bottom out unless you haul more than a couple 2x4 and some plywood or you want to tow something but the difference in price is only $70. Buy the kit with the c-notch, use the truck for awhile without the notch installed, if you don't need it I'll buy it from you.
I have yet to drive with my cnotch on but it looks like if you plan on towing anything you will need it for clearance.
the most i would ever have in it is my Honda TRX400EX and thats like maybe 3-4 times a summer to go to the dam and ride. but no towing i don't even have a bumper for a ball. (roll pan)
truck addict
i would go with the notch... i dont know where you live but if you hit one good pothole your looking at alot of shattered teeth... its better off in the long run f you notch it now and dont have to worry about it
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Generally I recommend one for anything over 5"
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
