01-06-2009, 02:15 AM | #1 |
BBC Horsepower???
An ideas on how much power this motor makes?
468 BBC 10:1 compression with forged pistons 090 casting ovals that are mildly ported solid roller cam with around 660 lift and a lot of duration stock rods stock crank edelbrock victor junior single plane intake 800cfm holley pertronix distributor It runs like a bat outta hell, just not sure on the actual numbers. Im guessing around 450? Let me know what you think. Thanks
Nick Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg 04 Silverado Daily Driver 68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665 "I'll beat you to the gas station!!" |
01-06-2009, 09:13 AM | #2 |
Re: BBC Horsepower???
Could be a bit more than 450hp.
01-06-2009, 10:48 AM | #3 |
Ready to go fast!!
im thinkin like 500 or 550? or more never know?
454 block .30 forged aluminum pistons steel crank valve job Holley Strip Dominator intake 1030cfm holley carb, 250 plate shot roller rockers Erson Solid cam split duration 307/310. .575/.595 lift milodon oil pan fab. aluminum valve covers 4 bolt main splayed anodized caps all studded |
01-07-2009, 12:13 AM | #4 |
Im suprised that you guys think it makes more power. haha. I was kinda shootin low though. I think the cam is a little big for the heads, but it sure does sound nasty. Anyone got any cheap ways I can sqeeze a little more power outta her. Thanks.
01-07-2009, 04:03 PM | #5 |
I doubt 550. Possibly 500 but im thinking 450+. Those heads are lacking. Ported and all they were never meant to flow well even with a roller cam. If you spent the $600+ on a cam why did you waste the money porting? after market Iron is cheap and will flow a ton more then those ported stocks will. Those heads are good for good low end TQ but not that great for high HP.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
01-07-2009, 10:32 PM | #6 | |
Nick Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg 04 Silverado Daily Driver 68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665 "I'll beat you to the gas station!!" Last edited by custom72c20; 01-07-2009 at 10:32 PM. Reason: spelling |
01-07-2009, 11:15 PM | #7 |
Sounds like a nice motor. I like nasty cams
01-07-2009, 11:46 PM | #8 |
i'm thinking around 525 or more.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
01-08-2009, 12:28 AM | #9 |
01-11-2009, 08:05 AM | #10 |
I entered your engine specs in my computer Dyno2000 engine simulation. It should make 500 to 550 hp. If I had more specifics on the cam, I could get a closer figure for you. I assumed stock valves (2.06/1.72) with some pocket porting.
Ray |
01-11-2009, 03:34 PM | #11 |
cool. Thanks. I'll see if I can find the cam card.
01-11-2009, 08:19 PM | #12 |
Welcome to the board!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
01-13-2009, 10:27 PM | #13 |
Right on the line, baby!
Ray: Welcome to the board from Philadelphia.
Nick: You didn't mention the rear ratio. That's one of the cheapest ways to get grunt. Looks like you gotta change your siggy since you're enjoying your bbc. Nice truck, BTW- -Todd
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly Click and scroll down for site vendors! Subscribe here! |
01-15-2009, 10:47 PM | #14 |
It's got 4.56 gears, so it leaves in a hurry. Haha. Hope fully I can get some pics and video of it soon.
01-16-2009, 08:07 PM | #15 |
After I wrote that I figured with that compression and duration, you'd probably have decent gears.
Always looking forward to vids!
