Doing a few items on LILRED66
I have my '66 Chevy C10 (LILRED66) at my shop at my house, doing a few miscellaneous things. Not much to show for, but I have been chasing an electrical gremlin and dealing with a pinhole leak in my factory Harrison 4-core Desert Cooler radiator. As with most of my projects, they start with a "short-list" of a few items and before I know it, I have a full page of "things to do".
In any case, I am having the radiator dipped, to clean up the build-up and leak tested/repaired, as needed. I am also repairing a few cracks in the original V8 radiator shroud. I decided to replace the horn relay, voltage regulator and condenser, to make sure everything is up to snuff. I had already replaced all the wiring harnesses during the initial assembly about 5 years ago. The battery was bad, but luckily still under warranty, so I am putting in a new battery...the alternator checked out OK, so it is going back in. I also decided to do the headlight relay upgrade on the head lights, while I had it apart. While I am at it, I decided to install a factory battery box, since the old one was not correct. These items, along with replacing several mismatched fasteners and the tailgate chain assemblies, I should have enough to keep me busy for a few hours. Last edited by LILRED66; 01-06-2009 at 07:40 AM. |
Re: Doing a few items on LILRED66
nice. im curious if the relay upgrade really helps. just out of curiosity, did you get a little frustrated with the radiator hose? lol
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
Good eye...actually, I am installing the factory "hard pipe" arrangement with the short hose pieces at each end, like the one pictured below. I just haven't installed the hard pipe or radiator yet.
nice Tony!
is that a factory washer fluid bottle and mount? you have anymore of those?
joe231:
It is a factory washer bottle and mounting bracket. I need to check my inventory to see if I have an extra factory bottle and mounting bracket. |
Custom Truck Lover!
nice. keep it up!
Hollister, CA.
![]() Join Date: Sep 2006
Nice work...by chance would you have one of those top radiator pipes ??
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
thanks Tony!
Junior Member
1 thing at a time is progress.
I was wandering about the upper hose as well. Now I understand. Looking great.
Alan
Philippians 2:14-16 |
Happy Camper
That is a neat looking rig, keep it up!
RIP El Jay! Love you brother! |
Resistance is Futile
I hate mismatched fastners!!!!
![]() ![]() ![]() ![]() ![]() ![]() Hewlett kills me: took a second to see that ![]()
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#13 |
I picked up this project about 5 years ago, in parts, from a fellow that had a change of heart. The photos are a little deceiving because the bed, cab and front clip were sit on the rolling chassis and loosely secured. The interior, engine bay, bed and plumbing were non-existent, so there was a lot of stuff involed, in putting it back together and getting it road-worthy.
In the process, I used the hardware, clips and fasteners I had available at the time. I have since acquired all the factory-style fasteners, clips and hardware, so when I pulled the radiator for repairs, I decided to replace those items with the factory-correct type. Although this truck is not "Number One" restoration, I wanted to have it as factory-correct as possible, with the parts/pieces I have available in my inventory. Plus, that beats needing to go to the hardware store and FLAPS several times during the process. Last edited by LILRED66; 01-07-2009 at 11:03 AM. |
#14 |
#15 |
How's it coming?
Alan
#16 |
I found a new reproduction radiator with the correct top & bottom tanks, although it is a three core instead of a four core. I found it at O'Reillys for about $200.00, plus tax. I check with many of the aftermarket truck parts suppliers and they were either way off or too expensive. I also checked several source online and they were about the same price as the unit I found at O'Reillys, so I figured I would go with it, since I could see it before I bought it. It was a direct bolt-in and appears to cool the truck properly.
I also did the headlight relay upgrade and that seemed to eliminate the electrical gremlin I was chasing. The headlights no longer flicker off and on. I need to do the final make-up of the plug at the radiator support, because the factory headlight harness at the radiator support is a two prong and the headlight relay plug is a three prong plug. I will take a few photos and post them, however they are not much to look at, since they are just the engine bay put back together. Thanks for checking in. Last edited by LILRED66; 01-21-2009 at 12:17 AM. |
