Old 01-06-2009, 02:28 PM   #1
AK72K10
AK72K10's Avatar
Cold Blooded
My 72 is my daily driver, it runs like a top (Normally), the rig has been gapped, timed & tuned (New plugs/wires/cap/condenser/coil/points/ect.) with a recent oil change (10W30), my MPG is right around 13 (Average) and the rig is garage kept. Recently we have experienced a 2 week span where the temperature has been anywhere from -5 to -30 degrees F, my truck starts fine & runs well initially, the heater functions as well as can be expected, warms the cab (New water pump/heater core/hoses/clamps/thermostat), and the radiator has been flushed with new fluid mixture added. My commute is approx 27 miles, after about 20 miles I have a stop light, and once I get there my truck idles down it will die. It never does that when the temperature is above zero and when I adjust the manual choke it only prolongs the inevitable sputtering death. It is 10x as bad after sitting in the parking lot at my work for 8 hours. I need some guidance here guys (Leaving the state and heading to a warmer climate is not an option, this is my only transpo and I cannot rideshare), any suggestions?
AK
______________________________
1972 K10 Custom Deluxe 350/350
2008 Suburban LTZ White Diamond
1972 F100 302
"Why Build It If You Can't Drive It?"
AK72K10 is offline   Reply With Quote
Old 01-06-2009, 02:38 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Cold Blooded
Are you running a stove-pipe set up? (the heat sheild that brings up hot air into your air cleaner)
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 01-06-2009, 02:48 PM   #3
ND_guy
Tool Addiction=Money Shortage
ND_guy's Avatar
Re: Cold Blooded
It sounds like you could be getting carb icing causing a restriction in the idle circuit. Does your pickup still have the inlet heater that warms the air entering the carb using the exhaust manifold? Do you have a working heat crossover system. They would warm the carb to prevent icing.
Carb icing generally only occurs between 15 degrees and 50degrees outside air temp but if the dewpoint is close to the actual temp icing in your situation could occur.
Just a thought.
1967 K20 400TBI SM465/NP205
posi front, Detroit locker 4.56 rear
ND_guy is offline   Reply With Quote
Old 01-06-2009, 03:01 PM   #4
AK72K10
AK72K10's Avatar
Re: Cold Blooded
"Are you running a stove-pipe set up? (the heat sheild that brings up hot air into your air cleaner)"_________________________________________________________________
Not sure about the stove-pipe set up, I am running a 14" aftermarket air cleaner sitting on an aftermarket 600CFM Carb, what do I need to look for here? _________________________________________________________________
"It sounds like you could be getting carb icing causing a restriction in the idle circuit. Does your pickup still have the inlet heater that warms the air entering the carb using the exhaust manifold? Do you have a working heat crossover system. They would warm the carb to prevent icing.
Carb icing generally only occurs between 15 degrees and 50degrees outside air temp but if the dewpoint is close to the actual temp icing in your situation could occur."
Sounds like you guys might be hinting at the same thing, I believe the carb may just be icing up, the temp outside is so cold that I figured it to be to dry out for this to happen but maybe I need to look into it a bit more. Any pics on the "stove-pipe" set up or the "inlet heater"?
AK
1972 F100 302
Old 01-06-2009, 03:07 PM   #5
ND_guy
ND_guy's Avatar
Re: Cold Blooded
If you have an aftermarket cleaner you don't have the stove set up. The stove is a pipe that ducts heated air from around the exhaust manifold to the air cleaner assembly. It aids in faster warm up and prevents icing.
Old 01-06-2009, 03:14 PM   #6
AK72K10
AK72K10's Avatar
Re: Cold Blooded
ND_guy are there any aftermarket air cleaners that would allow for stove set up? Should I look for an original cleaner or an OEM cleaner for winter use?
One other thing, the manifold is an aftermarket Edelbrock, I believe it is aluminum and not cast, if this is dissipating heat too fast could this also be contributing to the carb icing?
AK
1972 F100 302
Old 01-06-2009, 04:00 PM   #7
68350
68350's Avatar
Re: Cold Blooded
My 68 I drove to high school did it too when it was really cold in the morning. When it did it at stops, I just gave it some light gas and kept my foot on the brake. Other than that, it ran fine, so I never did anything about it.
The oem air cleaners are the only ones that will probably accept the heat stove. They are fairly easy to come by for small blocks, so it shouldn't cost too much money.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 01-06-2009, 04:14 PM   #8
AK72K10
AK72K10's Avatar
Re: Cold Blooded
Thanks 68350, after work tonight I will nurse my 72 over to my favorite parts store and see about picking up an oem cleaner. Only other problem I might encounter is the exhaust manifold and hose that leads up to the cleaner, I think the manifold has been replaced and the hose...well there isn't a hose. The P/O went through this truck in the 80's and restored it, and while that's the only reason it is still pretty much rust free, it is also the reason why it is not completely stock and I am encountering some of these other issues. I appreciate all your help, does not surprise me ND would come through concerning a cold weather question, I grew up in WI & MN (currently living in AK) and understand what you guys live with on a daily basis. Thanks again!
AK
1972 F100 302
