Old 01-06-2009, 05:01 PM   #1
willett
Another Day, Another Dollar
willett's Avatar
how hard is it to swap box-side skins?
here is the problem:
the current box on my truck is decent on the out-side sides, but is cooked on the inside especially where the wheel wells meet the inside-side(its a '78)
the new box for the truck is pretty mint, but doesn't have duel tank.
How hard would it be to take the skins off of the crappy box and put them back onto the good box?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 01-06-2009, 06:38 PM   #2
87Bob
Re: how hard is it to swap box-side skins?
Before I'd pull the skins I'd find a body shop to cut the fuel filler door into the good box. Years ago the show "Two Guys Garage" did something like that. It is just like doing a rust repair in a panel. Measure the panel with the fuel door (to get the position) cut the door out. Cut it in and stich weld it in place. It would be a lot less work than removing four panels and then putting two back on. Just stich weld it in a little at a time or you'll over heat the panels and warp them.
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 01-06-2009, 06:55 PM   #3
flamingbig10
6.0 powered square
flamingbig10's Avatar
I would relocate the filler house to inside of the bed
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 01-06-2009, 07:36 PM   #4
ont_guy_38
ont_guy_38's Avatar
Yes cutting out the filler door and welding it in would be way easier then drilling all the spot welds out of both box sides and welding it back on.I had a 69 El camino when I was young and when I replaced the quarter skins I did not cut out the filler door and relocated it into the box.No offence Flaming but boy reaching inside that box to pump gas soon got to be a pain
ont_guy_38 is offline   Reply With Quote
Old 01-06-2009, 10:51 PM   #5
willett
willett's Avatar
i did think about putting the door in the bed but my truck is lifted, and i haul alot of sh*t in the back.
just doesn't seem sensible for me..
Old 01-06-2009, 10:55 PM   #6
bigblock73
yeller
bigblock73's Avatar
The 73-87 box sides are bolted on, there are only a couple welds on the entire bed...back near the floor/tailgate area...everything else is a bolt on ordeal.
willett, here is an article for you to read.
http://www.73-87.com/7387garage/exte...ed_rebuild.htm
bigblock73 is offline   Reply With Quote
Old 01-06-2009, 11:06 PM   #7
willett
willett's Avatar
thanks for the link bigblock i was looking for something along those lines
Old 01-07-2009, 12:32 AM   #8
bigblock73
yeller
bigblock73's Avatar
No problem, glad I could help.
Old 01-07-2009, 07:59 AM   #9
ont_guy_38
ont_guy_38's Avatar
Maybe I,m not understanding then.When you said outside skin I thought you meant just the outside skin so if you are changing the whole bedside inner and outer skin then yes that just unbolts like bigblock says
Old 01-07-2009, 06:43 PM   #10
willett
willett's Avatar
no meant the outer skin, but it looks like a pretty intigrated part of the bedside
Old 01-07-2009, 06:43 PM   #11
willett
willett's Avatar
i was hoping for a quick fix so i can get this box on my truck, but it looks like i'm going ot have to do some cutting and swapping
