1 ton rearend swap options??
I have an Eaton HO72 with 4:10 gears. The truck is a dually with a flat bed. I intend on putting a Caddy engine in and want something with more highway friendly gears. Possibly in the range around 3:50 to 3:73 with a posi. I believe 14 bolt rears up until '86 or so are a direct bolt in, is this correct? Does it have to be off a dually truck or can it be a single wheel one ton. (is there a difference). Will newer rears fit? I could move spring mounts. Are they available with disc brakes? Any info or input would help.
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible. |
Re: 1 ton rearend swap options??
anybody?
I believe 73 and up dually rears are wider. I am not certain on that. That's about all I have to help.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Well...the 14-bolts started in`73 and that`s when the shocks started going one forward and one back.And,the spring pads are farther apart.Both easy fixes.The dual "pickup" rears are wide like a single pickup rear.The axles themselves iarethe same,just different lug studs,etc,for the dual wheels.A cab`n`chassis 14-bolt will be narrow.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-07-2009 at 10:05 PM. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I've got a 79 model cab and chassis 14 bolt rearend in my shop right now.
The spring pads are 40 inches apart, center to center.
I have a radical idea!
There's actually 3 different widths,Tim. The dually pickup rearends are even wider than a 3/4 ton or 1 ton SRW trucks. If you put dually rims on a SRW rearend they will hit the wheel tubs. The cab and chassis rearends are actually closer to the width of the SRW axles, but are a little narrower. The dually pickup rearends are way wider than both. I found this out when I built my dually. I used a dually pickup rearend out of a '97 C3500, but I had to move the spring and shock perches. As you can see in the first pic below, the hub sticks out past the bed side on the dually pickup axle. If put a SRW rim on it, the tire would stick out the wheelwell. I almost didn't put the dual wheel flares on it and left it like the bottom two pics. It looked like a railroad truck with just the inner dually wheels on it!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 01-07-2009 at 11:13 PM. |
