Old 01-06-2009, 06:03 PM   #1
P/S Box
I need a power steering box for my`72 K2500.I tore into it planning to use the N.O.S. steering box I bought in the`80s at the dealer.I painted it and went to do the pitman arm and guess what?GM had packaged a 2wd steering box and labled it with the 4wd part#!!
Since I need to go out and get a 4wd steering box,isn`t there a later one with a closer ratio I can get?What year would I ask for?What do you all recommend?
Old 01-06-2009, 11:24 PM   #2
Re: P/S Box
Hello??? Like,I wanted an answer right away?tsk sigh...
Old 01-06-2009, 11:30 PM   #3
skchevota
skchevota's Avatar
Re: P/S Box
Why not go crossover steering? it will steer way better, and you need a 2wd box.
Or you could change the sector shaft out for one from a 4x4
skchevota is offline   Reply With Quote
Old 01-06-2009, 11:34 PM   #4
skchevota
skchevota's Avatar
Re: P/S Box
If you do want to stay with the stock style linkage and get a new box, I would go with an ARG. You can tell them what you want as far as ratio as well. If you want a stock rebuild, I used one from a late 70s, early 80s truck. It still bolts riht in and has a closer ratio, but if you go to new like late 80s then the presure hose will need a metric end.
Old 01-07-2009, 12:13 AM   #5
Re: P/S Box
That`s it.I just need to stay away rom the metric fittings.This truck isn`t even lifted or used for real challenging offroad.It`s my utility vehicle.I want to do crossover on the shortbed project with a Dana60.I have a 2wd project I`ll use the mispackaged steering box on.
When I bought that box it was for a`71 and the number was up to`77.Do you think the`77-ups were metric thread or is a`77-80ish what would have the quicker ratio and sae fittings?
Old 01-07-2009, 07:15 AM   #6
vtblazer
vtblazer's Avatar
Re: P/S Box
FYI - I've got a D60 arm for a cross over set up I'm not using if you want it.
vtblazer is offline   Reply With Quote
Old 01-07-2009, 10:42 AM   #7
Burt4x4
Burt4x4's Avatar
Re: P/S Box
I have a 4x4 box I took out of my 72K5 when I did x-over you can have, it is fairly new from Napa, prolly ran on my truck for about 4yrs...no leaks...shipping may be $$ it's not light...my zip is 95356
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 01-07-2009, 11:23 AM   #8
Blue_71
Bloo
Blue_71's Avatar
Re: P/S Box
tim, on my 71 k20 im running a 83 box which according to napa is a closer ratio box. i bought a new hose, cut the metric end off the 83 in the junkyard that my box came from, and had the metric end crimped on my new 71 hose.
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 01-07-2009, 05:28 PM   #9
Re: P/S Box
Thanks or these reponses.One thing I`ve learned lookinig into this is I know a`78 will work and is a quicker ratio.The spline is different requiring the`78 rag joint to also be used.So,I think`77 was the last year the spline was the same and (maybe)`78 was the irst year quick ratio?The question is when did the fittings go metric?Hoses can be made.But,it`s cool to know a direct swap to an upgrade.
Burt,I`ll give what you want for that box.I`m not gettin`fancy with this truck.Just getting the steering tight.I`ve done bearings,ball joints,tie rod ends,then discovered the sector shaft play.I have draglink ends.Then,she`ll go straight and be all ready or a 4" lift.The springs and shocks are tired.
Kurt,will that piece work for the hi-steer?Not a priority right now,but I`ll keep it in mind.
Old 01-07-2009, 05:55 PM   #10
FormerMember
Re: P/S Box
Hoses went O-ring in 81
FormerMember is offline   Reply With Quote
Old 01-07-2009, 05:55 PM   #11
FormerMember
Re: P/S Box
You could also just rebuild the 4wd box you have:
http://www.pirate4x4.com/forum/showthread.php?t=570869
Kit's 15.00 at Napa.
Old 01-07-2009, 07:57 PM   #12
skchevota
skchevota's Avatar
Re: P/S Box
*1 sounds about right. I dont remember if mine was a 77 or 78, but it is the quick ratio and has the standerd fittings. I would see if the part stor would order the 78 up for you and then check it out when it comes in.
Old 01-07-2009, 09:21 PM   #13
Re: P/S Box
I found out that a`76 box was quick ratio in 2wds.`78 4wd sounds like a sae bet.This has trned more into info gathering for future reference.If I was buying another box I`d want the newer ratio.I already sold the worn box with a p/s change over I sold that a guy just needed the box for a core.Right now,it`s about budget and going straight down the road.If I can get Burt`s I`m all for it.
Old 01-08-2009, 06:32 AM   #14
vtblazer
vtblazer's Avatar
Re: P/S Box
It would but you'll need the 2nd arm on the drivers side to do high steer, the arm I have would get you cross over.
Old 01-11-2009, 01:31 AM   #15
Senator350
Senator350's Avatar
Re: P/S Box
I went to buy an AGR pump a while back and wound up at the person making them for AGR. He checked his shelves and didn't find any. I wonder where AGR is having their parts made? Lo and behold, they can just be built.
Is the power steering box an easy task as a "kit" would make it seem?
I can't remember the last time I got away with spending only $15 at the parts store...
RN U OVR
Senator350 is offline   Reply With Quote
Old 01-11-2009, 01:36 AM   #16
Senator350
Senator350's Avatar
Re: P/S Box
What tools do you need for crossover?
and what tools do you need for high steer?
tap & dye set (just tap?), verticle band saw (any hack saw?), 1/2 drive air tools (or not), ???
RN U OVR
Old 01-11-2009, 09:53 AM   #17
FormerMember
Re: P/S Box
For a Dana 60, it's a nut and bolt affair... depending on where you get your steering linkages from. Most places will tap the tube for you, or sell a weld in threaded sleave.
I use bigger DOM with weld inserts.
Old 01-11-2009, 01:40 PM   #18
Senator350
Senator350's Avatar
Re: P/S Box
nuts and bolts, for a couple hundred bucks, to fix your steering... not a bad idea. especially for a nice one ton truck
RN U OVR
