Grandpa in the rustmobile...
Ive gotta problem and a ?
okay, my truck used to have spotlights on both driver/pass. sides, so ive got 2 1" holes on the sides of the windshields, well when i get into the truck during/after it rains ive got lots of wet/dampness on my floor, which doesnt help the rust thats alreayd there....whats the best/cheapest way to plug these holes up they go thru the door and the roof support...................and I get water comming from the bottom of the door pannels? hows that getting in there???? thanks!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Resident of Here
Re: Ive gotta problem and a ?
Weld up the holes and grind em down, then paint over it. The piece of rubber on the outside of the window that rubs on the window is most likely not there, get a new one and it "should" fix it. I'm pretty sure that is what it is.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
its not that easy thirdstreet, when you open the door, its 2 1/2 holes one on the door, one on the cab roof support, so if you weld it up, then you couldnt open the door lol, does that make sense, id show pics but my SD card isnt showing up when i plug it in......
Weld the holes (no matter how many holes there actually are) and replace the window seals (top of the door panel, outside).
but if you weld the holes, the door would be welded shut, dangit leme get yall some pics of it im still tryin and it aint workin!
![]() thats the hole when the doors shut.. this is the hole with the door open.. ![]()
okay, wait guys, its a miracle, YALL'RE RIGHT
![]() i had to look at my own picture like 3 times before i understood i think, but im not for sure, i feel really REALLY stupid, forgive me ![]() weld up the outside hole, leave the rest, is that what you'uns were tryin to tell me the whole time??!!!?? CAN YOU SAY OOPS ![]() sorry, and somebody tell me im stupid and if im STILL wrong...
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 Last edited by oldblue1968chevy; 01-06-2009 at 08:42 PM. |
Fill those holes with......... spot lights!
I really meant for you to weld up the outside holes, then the inside (door) holes. cut and bend some metal, weld it in, grind it, etc....
expando foam!!...thats what the pervious owner used to fix a whole by the cab corner on my truck..but im fixing it right
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
wtf is expando foam lol never mind
ill def. weld up outside holes...dunno exactly bout inside ones mite just leave em for now..thanks i'll start the body work this spring wen its warm
![]() Join Date: Feb 2001
What he said!
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
if you wait to long you wont be able to cruise around in the summer when its warm with windows down and such..i am borrowing a buddies shop since he has heat and doing my truck there
#13 |
ok i'll try to hurry
#14 |
MOVE OVER
heck with it.. weld them doors SHUT, paint it up orange with a big flag on the roof.. and General Lee it!
you can always slide across the hood and climb in the window! dont forget the horn! J/K as you already have the answer figured out... ![]()
No matter where you are..... There you are... Buckaroo Banzi Last edited by rambler; 01-07-2009 at 08:06 PM. Reason: brain fart |
#15 |
Duct tape.
EdB |
