3/4 ton axles
Found some 3/4 ton axles with 4.10s, Dana 44 and corp. full floater 14 bolt for $275. Is this worth it? I have 3.73s now and running 35's but want to run 37's would 4.10 work?
![]() Join Date: Nov 2007
Re: 3/4 ton axles
Unless you're going for mpg, I think you'd be undergearded at 4.10s with 37s. You'd be better off with 4.56s.
Re: 3/4 ton axles
I agree with aj
but to answer the question that sounds like a good price to me if there arent any probs with them at least in these parts thats a good deal |
Re: 3/4 ton axles
Thats a great deal on those axles. Even if they need a rebuild. Grab'em!
Re: 3/4 ton axles
Keep in mind that if it is a 14FF and not a 14SF, the spring perches will need to be cut off and moved as well as the shock mounts. It's not a direct bolt in.
To answer your original question (sorry), that's a decent price, if they're complete and don't need major work. You won't be any worse off with 37s and 4.10s than you are currently with 3.73s and 35s. |
Not a bad nut after all..
Re: 3/4 ton axles
Won't the 14SF will still require shock mount relocation? Are the spring perches on the 14SF located correctly for our trucks?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
#7 | ||
Re: 3/4 ton axles
![]() Find a gear chart on-line, that will help you find the RPM's you'll be running @ speed and allow for a better decision to be made on your part. Quote:
Thought the 14FF only needs shock mounts changed... ![]() |
I'm a poor spectator
Re: 3/4 ton axles
Only if it's from a one ton. 3/4 ton 14 bolts need everything relocated if it's going in a 1st gen. If it's a 2nd or 3rd gen blazer the 3/4 ton 14 bolt is a bolt in (at least as far as spring perches go).
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
Re: 3/4 ton axles
Re: 3/4 ton axles
Thanks for your help. I will pick them up. I guess run the gears it has in it until I have enough money to run 4.56's.
Re: 3/4 ton axles
The dana 44 is still a half ton front axle with eight lug bolts which is what you already have accept yours has six lugs. Dana 60 is what you want in the front, the axles are much l;arger.
