Body drops? Z-frame?
Anyone have their 67-72 body dropped or their front frame/crossmember Z-d? I am looking to get the cab dropped down a bit to level it with the bottom of the frame, and Z the front end to get the crossmember up to the same level. Then bring it all together with an air suspension. The bed floor and rear frame will all be easy and quite simple to fabricate. I'm just curious if anyone has modified the cab floor, or just build a new floor and tunnel.
Re: Body drops? Z-frame?
Don't do it!!!!!. I did it and hate that I did it. I should have saved and bought a new front crossmember by Porterbuilt. There are so many problems that arise when you do this. Its a great big snowball effect and will cost you money. Stick with drop spindles and springs for now.
http://67-72chevytrucks.com/vboard/s...d.php?t=245203 Last edited by 68chevy68; 01-06-2009 at 10:33 PM. |
Thanks for the warning, i guess i'll put the torch down now.....
What kind of problems? I've done it to smaller trucks and I do realize that I will run into some "unexpected" modifications.
To name a few, steering, inner fenders will have to be modified, interferance problems between brake booster and valve covers, engine hitting hood, radiator fitting and also lower radiator hose. Mine goes through the frame. The more I do, the more i find needing modified. I am sure there will be more.
http://67-72chevytrucks.com/vboard/s...d.php?t=245203 |
![]() Join Date: Jan 2008
i personally would buy the new drop member for the 67-72 trucks
![]() ![]() ![]() and of course a body drop, which is not needed on a 67-72 ![]() ![]()
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 ![]() http://i195.photobucket.com/albums/z...en58/001-2.jpg |
