Has anybody out there cut coils or heated them for a drop?
Which do you think is better,cutting coils or heating them for a cheap drop? Has anyone tried either? If so,how much? I am down to a bare frame so I can't apply heat and go til I am satisfied. I figure that if anyone has done it they could tell me how much coil to take off. Yea,,I know that this is not the best way to do this,but it is the cheapest. That's what I'm going for.Thanks-Keith
Re: Has anybody out there cut coils or heated them for a drop?
tag
Have done it in the past cut one coil at first then go from there...dont like heating
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Saving 1 truck at a time!
Cut the fronts and heated the rears (can't cut the rears due to the mounts)...been running them for about 5 yrs...no problems....except the stiff ride...LOL! Temporary since I am going to bags.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
Droppin' It Like It's Hot!
I took about one coil off of mine on the front and heated the rears until I got the stance I wanted.
Robert
Life Member RIP CAROL JANICE HARTMAN. BELOVED MOTHER. 01/04/53 - 03/05/09 1969 ![]() Norwood, MO 2007 Big Sandy, TN 2008 Had nothing to do with the forklift! Kirkwood, MO (Midwest Meet 2009) Midwest All Truck Nationals, KCMO - 2008 - 2009 - 2010 - 2012 - 2014 SUPPORT THE SITE HERE! |
![]() i cut 2 coils up front, 6in drop springs out back |
my truck has heated coils all around, it's dropped i'd say a good 3 inches
If I had a limited budget I would cut the front, and buy drop springs for the rear.
I had a truck that the PO had cut the front springs and heated the rears. The front was an uncomfortable ride, but nothing I couldn't stand. The rear was horrible. You can't cut the rear coils, they have special ends used for mounting. Your best choices are heating or replacement. Do you plan to haul anything in your truck? Heating will kill the majority of your ability to haul a load.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Ive done them both ways in the past. I prefer to cut them. Put a set of chevelle coils in the back & cut one coil in the front. Any more than that, would require getting the billfold out of the back pocket to be done correctly.
I cut the front and heated the rears as well. I cut two out front, loaded some cinder blocks in the bed and torched the rear. Heating the springs aren't really the best way to do it because it makes them more brittle, however, I have loaded the bed of my truck with dirt (to the rail with the tires about to pop), but never had a problem. I think it would be a real problem on girly little import springs, not the manly chevy springs we're running.
I've loaded the crap out of mine with the heated springs and haven't had any problems. Of course it rode very rough and on the bump stops the whole time. Had a riding lawnmower, my 5.3L engine, engine hoist and push mower in the back.
Robert
#13 |
Last year, me & 70c10 cut his fronts. PM him as I can't remember how much we cut off. Worked out good. I would not us heat, as you don't have control on the amount of heat used for each side.
1997 GMC Sierra Ext 1965 Mustang |
#14 |
Thanks guys. Lots of good information ,as usual. This gives me something to go by. -Keith
#15 |
When cutting I think 1 turn is equal to about one inch... I agree with others.. Cut the front and replace the rears.
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
#16 |
If you want any ride quality at all do neither and buy a set of drop springs.
When I bought my truck some kiddo had cut all four and it rode like a buckboard. If you heat them they lose their strength. I'd pas on both methods.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
#17 |
Too many toys,not enough money
I just cut the fronts on mine, 1 coil cut off will get you 2" - 2 1/2", depending on sag of coil. For the rear you can do a lowering block to get a few inches.
#18 |
1970 Daily Driver
Cut the fronts and make some drop blocks for the rear out of some scrap tubing. We did that on my brothers truck and sometimes I think it rides better that my kit from CPP on my truck. I know it hauls loads better
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
#19 |
is very serious
how much drop did you do?
1967 C-10 2wd fleetside LB 350 4spd (dads) - sold 1970 C-10 2wd fleetside LB 307 700r4 - sold ![]() 1969 C-10 2wd fleetside LB 327 3spd - sold ![]() 1969 C-10 2wd fleetside LB 350 th350 - sold ![]() 1967 C-10 2wd fleetside LB 250 th400 -project in progress Chevrolet=one who is dignified enough to expect every occasion is a special one and sees it fit to wear a bow tie... may others come under dressed. |
#20 |
When you heat them, heat at the bottom-not in the middle; I dropped a long box about 3" all around this way and it rode fine; wheel align was still in spec too.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
#21 |
is very serious
yea iv made that mistake on my impala and it crushed side ways.... u think you could have gone lower than 3inch? im looking for a cheap way to go 4/6 or so...i dont care to much on ride qaulity...
#22 |
Spose you could go low as you want....I just wanted it to "settle" a bit.
#23 |
is very serious
i see what you mean... i just want that obviously lowered look... wont to be to hard considering mines a long bed and long and low is an easy look but still. i like the route u went with the ralleys... i cant decide between white wagons or ralleys... keeping it six lug tho
#24 |
![]() Join Date: Jan 2006
Everybody has done it...it's just not a good idea. Unfortunately, sometimes it's a matter of the budget, but you still want to get the look without spending a bunch of money. I'm going to go along with stllookn's advice...if you are going this way, cut the fronts and heat the rears. If you can, try to get drop springs for the rear, it will help maintain a degree of ride quality. Cutting the fronts will give you the drop, although they will "stiffen" up and your ride quality will be affected.
don "The DRBMan" 2014 Audi A4 (The Wife's Daily Driver) 2017 HD Ultra (The Cruiser) 2003 HD Fatboy (The Ride) 2001 Chevy Suburban (Another back up!!) For the first time in forever, not a single 67-72 Chevy truck, Blazer, or Suburban on the property! Basically retired and getting the new Motorhome ready for some traveling. Doing a bit of work on the house getting it ready to sell! LOL!! |
#25 |
I,ve been curious on the chevelle springs they look very similar but are thinner,how are these working for you?what kind of drop did you get from them,can you put anything in the bed weight wise?I have a new set that was bought for a 67 that Ive been holding on to just too try sometime is it worthwhile?anybody else try this?
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
