HO72 frustration
I finally got may hands on an old 7200# third member from a friend of mine for a axle project I'm working on. This way I can swap out the 5200#third in the project axle. So I tore it down and started wire brushing the usual rust off the ring gear and discovered the drive side is shot. It looks like it hauled scrap iron for a living from day one (1949), while low on oil. Not all is lost, at least I have some parts I guess.
86 Chevy K30 Crew Cab, USAF(retired), TH400/NP205, 28K miles 99 Chevy (88-98 Style) Reg Cab LS, K2500 454, nv4500 92 Dodge, Cummins, SLED PULLER, 5'' hood exit, NV4500UHD, dual disk clutch, Borg Warner S400 charger, GM 7200#/14B hybrid rear Dads... 69 GMC k2500, 427, 4 speed, Rockwell 221, 7200# rear, detroit, disk brake front, 5.13's Last edited by Longhorn Man; 01-07-2009 at 12:34 AM. |
its all about the +6 inches
Re: HO72 frustration
The 3rd member on every HO52 and HO72 were the exact same, load deflection bolt and all. The only thing I've seen between the two, is the brakes.
Well, Whoop-dee-do!
![]() Join Date: Mar 2003
Not all of them have the deflection bolt. Early carriers & gears (50's?) are different than the later design. I can't remember the year they changed or the exact differences, but IIRC, the pinions are different length. You can't put an early gear set in a late carrier or vise- versa. But you can swap complete third members between early & late housings. I think the u joint to axle centerline measurement is different between the two also.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD ![]() '72 K20 500 Cad/TH400/NP205 SOLD ![]() '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car ![]() |
Well, Whoop-dee-do!
I just noticed you are a NE puller... do you pull with NPPA? If so, which truck is yours?
Good call Jeff... i was talking 67 - 72, I forget they made trucks before 67!
Well, Whoop-dee-do!
But we all know you don't acknowledge the '73 up trucks
73 and up what?
#8 | |
I don't run NPPA quite yet, I do go to some of the local events they tie into and was at Platte City, MO last year. I thought 4.57's are supposedly the most common ratio for these?
86 Chevy K30 Crew Cab, USAF(retired), TH400/NP205, 28K miles 99 Chevy (88-98 Style) Reg Cab LS, K2500 454, nv4500 92 Dodge, Cummins, SLED PULLER, 5'' hood exit, NV4500UHD, dual disk clutch, Borg Warner S400 charger, GM 7200#/14B hybrid rear Dads... 69 GMC k2500, 427, 4 speed, Rockwell 221, 7200# rear, detroit, disk brake front, 5.13's |
#9 | |
other than that, the 2 3rds i have agree with you. '65 4.57 '52 with a no-spin, and a '68 5.14 '72 with the load bolt, extra oil passages, open carrier with 4 spiders.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 Last edited by 1969 GMC; 01-07-2009 at 11:20 PM. |
#10 | |
I took a bunch of photos of 5200# and 7200# axles and compared parts with a 14 bolt FF as well. I also researched the GM service information as well. I was thinking of doing a tech post, what does everyone think? Somebody has to have a load bolt third member with 4.57's close to me surely?
86 Chevy K30 Crew Cab, USAF(retired), TH400/NP205, 28K miles 99 Chevy (88-98 Style) Reg Cab LS, K2500 454, nv4500 92 Dodge, Cummins, SLED PULLER, 5'' hood exit, NV4500UHD, dual disk clutch, Borg Warner S400 charger, GM 7200#/14B hybrid rear Dads... 69 GMC k2500, 427, 4 speed, Rockwell 221, 7200# rear, detroit, disk brake front, 5.13's Last edited by stillsmokin; 01-08-2009 at 12:25 AM. |
There aint no body like a square body.
Had to say it.
77 Cheyenne no longer in bits ![]() |
Yes, those are the trucks I grew up with and love. The rust not so much.
Anymore, if it was made in america it was cool. If it has a bowtie or GMC logo on it, it's all good.
