![]() Join Date: Sep 2005
temp gage help
okay my roommates dad has a 97 s-10 with 4.3 vortex. anyway his temp gage does not work hasn't worked in about a year problem started after ti blew the water pump gasket and over heated. we tried a new sending unit did not fix the problem. tested the gage by grounding the wire and it peged red hot doing this. emp gage just sits on cold any ideas where to look next?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Re: temp gage help
Are you sure you replaced the correct sending unit? Not saying I know for sure, but I have worked on several that had more than one temp sending unit.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
Re: temp gage help
replaced the one in the side of the driver side head. grounded the wire going to that unit and Gage pegged red hot
BAD BOW-Silverado XST
Re: temp gage help
96 and 97 engines have the sensor near the thermostat. 98 and new have it in head.
http://www.autozone.com/shopping/rep...00c152800bfd33 |
Re: temp gage help
shop key says it is in the head and i dont see one around the t-stat
Re: temp gage help
Ive heard that there are two also. One for the gage & one for the computer. I have a 96 that took out the pump at one time & my gage reads cold all the time even after a different cluster.
Re: temp gage help
I did some work on a guage cluster yesterday. Fuel guage wasn't workng, after further investigation, I found it had a bad connection on the circuit board. Fixed that and it worked.
hometown heroes!
Re: temp gage help
My temp gauge go's way up, but the truck doesn't seem to be running that hot.
2009 Silverado 2wd, 121k as of 04APR13. I love my truck 29 days out of the month. The payment is due on the 30th... ![]() Do your duty in all things. You cannot do more, you should never wish to do less. -Robert E. Lee "Never give up ground you've already taken." -Unknown |
Re: temp gage help
Was thread tape used on the sender? If so, that could be causing the new sender not to have a path to ground.
I can still count my vehicles on two... wait three hands. Last edited by Damien; 01-20-2009 at 02:45 PM. Reason: spelling |
Re: temp gage help
I have a very simular prob. in my 93 (with 95 motor) my temp gauge stoped working i replaced the temp gauge by the tstat did not change. here is the stange part if i pulll the fuse the temp gauge works and all other gauges die.?????
sorry if i hijacked your thread... Last edited by redsean; 01-22-2009 at 06:30 PM. |
#11 | |
Re: temp gage help
When you pull the fuse you are opening the circuit, and will have infinite resistance. The gauge should go to hot. I would check the wire on the driver side head to make sure it is connected and not broken. You could check resistance in your sender with a DVOM. The reading should not be infinite, maybe a couple hundred ohms?? Ground to base, red to terminal.
I can still count my vehicles on two... wait three hands. |
Re: temp gage help
thanks man. much help
#13 |
Re: temp gage help
i sensor had tread sealant on it from when we bough t it
#14 |
Re: temp gage help
Thats OK. Sometimes people will tape the treads with too much tape and there won't be a good ground.
