Stock gear ratio ?
Have an all original '69 C-10 . It's a 307 and three speed . What do y'all figure the gear ratio is ? Must be around 3.73 or so , as I can start from a dead stop in second gear pretty easy . Is there an easy way to find out ? THANKS !
ASE master tech/machinist
Re: Stock gear ratio ?
3.73 is the most common stock gear found in the 68-70's.
its all about the +6 inches
witha 3 speed manual in a 1/2 ton, 3.73 would be base equipment.
THANKS for the replies .
welcome to the forums from central ohio
THANKS for the replies and the welcome . I've already learned a few things .
1970 Daily Driver
I just found this site with a good decoder. You can find your axle production code on the top of your passenger side axle tube and match it up with their list. They also have, Color Codes, Model Codes, Engine Codes, and Transmission codes.
http://www.americanclassic.com/paint.htm?p1=axles
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
