01-07-2009, 07:25 PM | #1 |
20x14 rear rim
Hi is it possible to use a 20x14 rim with 4.5 bs on a 70 stepside with a 4 or 5 inch drop and only narrow the rearend or would you have to modify the frame and bed plus what tire size would you run thanks alot and pics would nice thanks alot for any input.
01-07-2009, 07:29 PM | #2 |
Re: 20x14 rear rim
I don't think you would have to modify the frame, but I'm pretty sure you would have to mod the wheel tub area on the inside of the bed.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
01-07-2009, 08:26 PM | #3 |
Re: 20x14 rear rim
Modify to make tubs but other than that im pretty sure its only the rear end you have to modify.
you can run a 15 or 16 tire with that wheel.
Travis
travis_moffatt@hotmail.com 1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces. 1991 GMC Sonoma, IROCS s10 grill 1963 Ford Galaxie 351/C4 |
01-08-2009, 05:39 AM | #4 |
slims 68
Re: 20x14 rear rim
I'm planning on going with a 29x18x20 M/T sportsman S/R on a 20x15 rim with about 7+ inches of drop. I know That I'll be realy close with the frame and may have to trim a nipple hair out of the frame. It's also going to be close to the inside of the fender as I'm having to basically square them out. My rims will be at about 9" backspacing on my stock 12 bolt, with the 4.5 that your talking will deffinatly need a norrowed rearend.
68 c10 LWB, blown 454 , 550 hp & 600 tq est. 06 Chevy Cobalt SS supercharged 2.0L 08 Chevy silverado crew cab 1/2 ton 2wd 5.3L, she wont let me put a supercharger on it. Last edited by Tmiller; 01-08-2009 at 05:44 AM. |
01-08-2009, 03:33 PM | #5 |
A guy with a truck
Re: 20x14 rear rim
I was planning on this exact setup on my '70 before I decided to do IRS. They will fit without cutting the frame, but you will need to remove the bumpstops and mounting brackets.
You will have to narrow the axle 5" per side/10" total. The trailing arms will be a tight fit, but will fit inside the wheel hoops. The bed will need to be tubbed to the rails- about 6". They are easy to build out of your stockers plus an extra set. Mickey Thompson S/R s are a good fit. There is a 29/16-20 and a 31-18/20 that should work, but the 18" wide tire will be dangerously close to the framerails and bedsides...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
