![]() Join Date: Sep 2005
IS there an easy way to install doors?
Trying to install my doors and I would make a sailor blush
MOVE OVER
Re: IS there an easy way to install doors?
call a buddy.
I have seen someone fab a door gig to do one person installs, not sure if it is in the FAQ section.. I'm not sure when I will be up in that area, or I would give you a hand...
No matter where you are..... There you are... Buckaroo Banzi |
i had the same problem, not enough hands. i used my floor jack rolled the jack up next to cab & sit the door on it& eased it on up , worked great.
What have I gotten into
I did as T&T did. A floor jack with a jackstand helps alot. Not as good as a buddy, but it did work. Then I made the mistake. I thought, I don't have a buddy near by, I'll just ask the wife. Well, unless you want a divorce, DO NOT ask the wife. Poor thing. I had to hold the door, and she was TRYING to start the bolts. Oh my. What a mess.
someone makes a dolly specifically for putting doors on.
i don't feel like searching the web tho... *edit... why the hell not... http://automotive-door-dollys.brutmfg.com/ from what it looks like, this would be pretty easy to build. it might even be easier to add or convert a harbor freight engine stand into a door dolly.
RN U OVR Last edited by Senator350; 01-07-2009 at 08:14 PM. |
I had to take the fender back off to do it but I think the drivers side is done. Tell me what you all think.
engine hoists lift all sorts of stoff why not a door it's only a matter of balanceing while lifting
I know this is gonna come back to haunt me but I have just got to say, that is the tightest crack I have ever seen, any tighter and I wont be able to get in the darn thing.
I put the hinges on the cab then lifted the door and just held it up and finger threaded. Hard work but it didnt take too long.
Travis
travis_moffatt@hotmail.com ![]() 1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces. 1991 GMC Sonoma, IROCS s10 grill 1963 Ford Galaxie 351/C4 |
without the fender on you can put the door on pretty easily by yourself. you just slide the hinges in first and then latch the door as if it were attached and you only have to hold up the hing area whill putting the bolts on.
(Only) Member of the CPNE Fan Club ![]() ![]() 67 C-10 350 with 3-speed tranny and 308 gears swb step ![]() 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
