01-07-2009, 09:33 PM | #1 |
tach wiring diagram?
im putting a factory tach in my jimmy but dont know how the wires hook up to it! if anyone has a link to a diagram of can talk me through it would be great
01-08-2009, 08:58 AM | #2 |
Re: tach wiring diagram?
Do you have a HEI or points?
BTW, Welcome to the boards from Philly
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-08-2009 at 08:58 AM. |
01-08-2009, 10:32 AM | #3 |
2 wires needed for HEI (don't have any trucks with points)
1 wire from the back of the tach (marked coil) to the tach post on the HEI on the engine (spade connectors on each end) - light brown wire from factory if you are going for that look. 1 wire from the back of the tach (marked 12v) to an ignition unfused connection on the fuse block under the dash - could use the cigar lighter opening if you don't have a lighter. That is it... |
01-08-2009, 01:05 PM | #4 |
Its lookin' like a Blazer!
This is a sticky in the electical forum.
http://67-72chevytrucks.com/vboard/s...=185856&page=5 check posts #104, #112, #122 Everyone should save these diagrams to your computer. Handy stuff. |
01-08-2009, 06:07 PM | #5 |
Thanks J for that, just downloaded it to my Tech. Favs.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
01-08-2009, 10:39 PM | #6 |
Thanks J for the links. will be using them soon
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
