Old 01-07-2009, 10:23 PM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
Wood Floor Finishing Help
I know I have seen several posts on here before about what is the best stuff to use when finishing wood floors. But tonight I can't find any of them. So sorry for starting this again, but what has everyone used??
1971ChevyTruck is offline   Reply With Quote
Old 01-07-2009, 11:05 PM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: Wood Floor Finishing Help
My dad and I used Waterlox products for boats on his GMC. I like the fact that there is no clear to peel off, and it can be touched up if it gets scratched. Sorry, no pics of the bed and the truck is about 150 miles from me now at my dad's.
http://www.waterlox.com/site/559/default.aspx
WIDESIDE72 is offline   Reply With Quote
Old 01-07-2009, 11:38 PM   #3
chipflyer
chipflyer's Avatar
I used manowar spar varnish. Also used on boats, and has lots of UV protection, it can not be sprayed though. If I were to do another I might use automotive clear. It would be much easier than brushing on 4 coats on both sides of the boards.
http://www.valsparglobal.com/val/resident/manowar.jsp
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 01-08-2009, 06:52 PM   #4
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
I am using Bristol Finishes Amber Urethane. If I had not already purchased it, I would most likely go with automotive clear also.
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 01-08-2009, 07:43 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You need to decide what you will use the truck for and whether it's to be parked inside.UV is one of the worst things on a finish.Either way make sure you do the end and edge grain of the wood.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-08-2009, 08:12 PM   #6
mbgmike
Mar-K has some good test info on their website. We use a good quality Urethane sanding between coats and then coat with automotive clear. We usually use a mat finish unless the customer wants it glossy.
http://www.mar-k.com/wood_finish_testing_i.html
mbgmike is offline   Reply With Quote
Old 01-08-2009, 08:29 PM   #7
1971ChevyTruck
Thanks all...Mar-K states that MinWax was one of the best they tested. This will not be parked outside much. So I think I might use that with a light oak stain. Or I might go with a natural stain. I'm just not sure yet.
Old 01-09-2009, 12:54 PM   #8
mbgmike
The picture above has no stain at all for reference.
Old 01-09-2009, 01:17 PM   #9
Richard Dobson
Marine spar varnish, with a light sanding in between coats with 220 sandpaper. I used white oak which has good durability to weather.
Richard Dobson
Richard Dobson is offline   Reply With Quote
Old 01-09-2009, 01:58 PM   #10
gonline71
gonline71's Avatar
I highly recommend Bruce Horkey....he has a kit for both short and long beds which includes sand paper, 3m pads, stain choice, varnish, brushes, tack cloth and directions. Amazing products!
He uses Spar Varnish as well
http://www.horkeyswoodandparts.com/
gonline71 is offline   Reply With Quote
