heater hoses to engine swapped?
just out of curiousity what would happen if someone were to swap the two hoses going to and from the heater that connect to the intake and to the water pump? what would be the effects if any? would it cause the engine to over heat?
Re: heater hoses to engine swapped?
EDIT: Read the post wrong
it isnt somehting i was thinking about doing its more of somehting i think i may have done. anyone know which one should go where?
Hybrid67
Hose sizes coming from the heater core should be sized to accomodate the correct fitting on the intake and the water pump. I found out I had mine switched by forcing the wrong hose onto the bottom of the heater core and snapping it off. Not fun replacing stuff due to ignorance. I have the top hose from the core into the intake and the bottom to the water pump. I haven't had any issues. Hope this helps. Not really sure what the outcome is of switching them.
i just went out to make sure and mine are matched up the same way. this came up because my truck started heating up tonight and not sure why ...i have been driving it for a while and its been doing fine and all the sudden tonight it went to 210 i have a 180 thermostat in it the only thing i can think of is that it went bad or is stuck. guess ill go buy another one tomrrow. anyone have any other ideas?
![]() Join Date: Dec 2006
The two are different sizes,as mentioned above,( 5/8" and 3/4" IIRC) but I don't see how having them reversed would cause any problem at all.
On mine, I have bypassed the heater altogether and there is no difference.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
i kind of ruled the hoses out as reason for the overheating but i figured id ask anyway. now on to figure out the real cause. gotta sart someone right?
#8 | |
Gone to greener pastures
![]() Join Date: May 2007
You can take thermostat out & put it into a pan of water on the stove. Put a fire under the pan & see if the thermostat opens. If you have a candy thermometer, clip it to the side of the pan, but don't let it touch the bottom. That way you can see exactly @ what temperature your thermostat opens. If the thermostat works, start looking elsewhere. Start with the simple stuff, is the radiator full, etc? And then move on from there. That's a lot cheaper than just going out & buying parts. If you don't have a candy thermometer, go to the grocery store & buy one. You'll need it for making fudge anyhow. Just my .02.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
its all about the +6 inches
having them swapped would not anve any ill effects on your engine, heater, air temp, nor coolant temp.
If you managed to pull it off.... no one would ever know. Till one popped off due to size incompatibility anyways. ![]() |
![]() Join Date: Sep 2005
210 is still normal to me i like to see cars run between 180-215. course the cool the motor the better the preformance
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
The Older Generation
#1 - Make sure your fan belt is tight.... LockDoc
210 just scares me ive never had a car or truck run that hot. but ive heard that from someone else that that is normal as well. the only other hting is that when it gets to 210 it smells hot.
i didnt think of the fan belt ill check that this afternoon |
#13 |
I had an experienced mechanic here in town recommend a warmer thermostat in my 327 based '36 Ford Coupe. I had a 185º in it and he recommended a 195-200º. I followed his recommendation and for the first few days it smelled hot too but it went away after driving it for a while. I don't consider 210º a problem. If it boils over... that's a problem.. ![]() LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-08-2009 at 01:38 PM. |
#14 |
Firefighter
It will work fine, and the hoses can be reversed, it is just a real pain trying to get 5/8 hose over a 3/4 fitting, but it will fit!!!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
#15 |
I am a Referee of life.
I reversed mine.I don't remember having a problem getting them on and haven't had a problem keeping them on.I'm kinda AR about stuff and didn't like the hoses crossing under the hood.When I asked someone else said they had done the same for the same reason.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#16 | |
That's why temp gauges are marked C-----H, rather than in degrees; so drivers don't soil their laundry when they see the temperature. If I'm wrong, somebody correct me, please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
