Old 01-08-2009, 02:15 PM   #1
mainermikeyd
mainermikeyd's Avatar
Bed cross rail problems
Alright guys, lookin to replace the bed cross rails on 8' fleetside, was lookin at replacin the whole bed or floor, but one it costs some significant $$ to ship, two the rest of my bed is in REALLY decent shape, minor scale rust but no rotten panels!!! I see so many SWEET trucks on here was wondering if anyone has had a similar problem or found a replacement part for these through either a distributor or fabricator!!!! Any help or info would be appreciated THANKS
Once a Marine Always a Marine OOH-RAH
GM Fanatic
1982 K20 4" Rancho lift 350cid, edelbrock performer intake 1405 carb, hedman headers, TH350, " Wheres the MUD!!!!!!!!!!"
1986 c30 camper special 454, th400 (for sale)
1984 K10 Big Ten (project) needs motor
1984 C10 355, 700r4, (project) needs shortbox bed
mainermikeyd is offline   Reply With Quote
Old 01-08-2009, 02:25 PM   #2
87c10slammer
truck addict
Re: Bed cross rail problems
im not sure of the exact measurements but i plan on using box tue or similar to do my bed. but then again im doing a body drop on it so i am making my own bed height...
87c10slammer is offline   Reply With Quote
Old 01-08-2009, 02:57 PM   #3
ont_guy_38
ont_guy_38's Avatar
I had a place that makes dump boxes,replacment flat beds and stuff bend mine up.Way cheaper and believe me they are heavy duty compared to anything aftermarket or the orignals even
ont_guy_38 is offline   Reply With Quote
Old 01-08-2009, 06:09 PM   #4
James McClure
One shot, one kill.
No one makes the cross beams you are refering to. They are usually in worse shape than the bed itself. You will have to make them or have them made. My bed was in such bad shape I had no choice but to replace everything except the front panel.Now it's done up right. The whole inside and underneath is sprayed with bed liner. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 01-09-2009, 07:57 AM   #5
87Wrangler454
87Wrangler454's Avatar
I am in the process of doing the same repair on my 87 long bed. I found the cross rails at my local crosscanadaparts.com supplier, they are 72" x 3" pre bent galvanized heavy gauge steel and sell for $40 Canadian (about $32 US) each.
You have to cut and weld some short pieces of pipe were the carriage bolts pass through and punch some holes in them so you can spot weld them on.
They also sell the tailpan assembly complete for $214, mine was missing and somebody had welded channel iron in place of it. I also stripped the paint off the bed floor and found it to be galvanized steel and in good shape since the previous owner had a bed liner in it. Good luck it takes a while to drill all the spot welds out.
The small middle rails I could not find new but once I drilled them off they look repairable and will reuse them.
87Wrangler454 is offline   Reply With Quote
Old 01-09-2009, 08:21 AM   #6
ont_guy_38
ont_guy_38's Avatar
I had all mine bent up inclucing the tailpan assembly for 120 dollars
Old 01-09-2009, 07:16 PM   #7
chevymotocross
chevymotocross's Avatar
You are not alone! That is what is left of my rear rail on my 87 shortbox. The rest of my bed is pretty decent. It is ashame. As you have found out, no one really makes these. I think Raybuck sold them at one time, not sure, I will have to check again. This spring, whatever it takes, I am replacing that brace as well as the tailpan which is also pretty shot. The dirt, salt, sand, road debris, etc, collects all up in there, causing the rot.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 01-10-2009, 12:22 PM   #8
mainermikeyd
Thanks 87wrangler, that is what I needed to know, and the last thing I want to do is put the same spagetti thin metal GM put on these trucks!!! I only wanna do this once so I want a thicker gauge metal!!! Thanks
GM Fanatic
Old 01-13-2009, 08:43 AM   #9
87Wrangler454
I checked the bed rails and they are 16ga. (.063) thick steel.
