Old 01-08-2009, 08:34 PM   #1
gcburdic
Restoration Virgin!
gcburdic's Avatar
Did I install my front shocks backwards?
Here's a pic of my install of these shocks that I bought/ installed from CPP back in 2006. I finally brought my truck home about a month ago and noticed a small puddle of an oily substance below the lower passenger a-arm. After trying to locate the leak, I noticed that white bubbles were forming around the shock shaft where it meets the cylinder. did I install these wrong or is the shock going bad?
Thanks for any input....
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 01-08-2009, 08:38 PM   #2
spr85gmc
spr85gmc's Avatar
Re: Did I install my front shocks backwards?
up side down i believe
spr85gmc is offline   Reply With Quote
Old 01-08-2009, 08:59 PM   #3
LONGHAIR
"Upside down" mounting is a fairly common thing with shocks that don't have a rigid bell-type cover over the shaft. Some say that there is a performance advantage to be had because of the reduction in un-sprung weight, but on a pick-up truck....are you ever going to notice?
Either way should be fine, depending upon how the internal valving is configured. If they are a true 50/50 or some "velocity sensitive" type, they should work the same either way. If not, their may be some difference.
As far as the leak, it's not a gravity thing. If it leaks upside down, it will right side up too.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-09-2009, 12:28 AM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
Thanks for your responses...I guess I'll try to see if they have any kind of warranty on them since it is leaking.....wish me luck trying to get that done with CPP!!!!
Geoff with a G
Old 01-09-2009, 01:22 AM   #5
XXL
Seņor Member
XXL's Avatar
They look right to me...
XXL is offline   Reply With Quote
Old 01-09-2009, 09:11 AM   #6
gcburdic
Restoration Virgin!
gcburdic's Avatar
Ahhhaaaa....I knew they were on upside down!!!
Thanks for the fix XXL....
Geoff with a G
Old 01-09-2009, 01:33 PM   #7
MickMc
MickMc's Avatar
Upside down is fine...
But
The nice pretty chrome shaft is now more exposed to rock chips (if you drive your truck). Chip and nicks in the shaft will tear the seal and the shock will leak (just add some black shock boots).
Yes un-sprung weight very important, (insert 4 million technical pages of data) but it is a truck that is most likely cruised and not raced...but making people point and wisper is alot of fun too.
Mick
MickMc is offline   Reply With Quote
Old 01-13-2009, 02:14 PM   #8
Tony@AirRideTech
Junior Member
it shouldnt matter if they are updise down if it is a hydraulic shock. If it is leaking at the piston shaft she is done.....
Tony@AirRideTech is offline   Reply With Quote
