Old 01-09-2009, 01:09 AM   #1
MonteSS454
MonteSS454's Avatar
'73 and up controls arms
I've noticed alot of people swapping to '73 and up control arms.
Whats the reason for the swap? Better ride? Lowers a bit?
Last edited by MonteSS454; 01-09-2009 at 01:14 AM. Reason: Can't type in the dark to well.
MonteSS454 is offline   Reply With Quote
Old 01-09-2009, 01:48 AM   #2
Aarons72s
Re: '73 and up controls arms
The 73-87 1/2 ton a arms use rubber bushings instead of the 63-72 solid bushings where the control arm shafts atach to the a arms. Some people think they ride better, especially with urethane replacing the rubber ones. I personally prefer older solid ones. You keep them greased and they last prettymuch forever. The newer ones usually have to be replaced every few years as the rubber breaks down.
Aarons72s is offline   Reply With Quote
Old 01-09-2009, 07:36 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
They're using them mainly because they are more readily available.
Old 01-09-2009, 12:51 PM   #4
MonteSS454
MonteSS454's Avatar
Thanks guys, was just wondering.
Tx you are right about that. I think I have a few sets in my barn :P
Old 01-09-2009, 06:21 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The Ball joints are also cheaper so if you switch to disc brakes by using later model control arms and disc it cost's less to rebuild the front suspension.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-09-2009, 07:05 PM   #6
Aarons72s
You can put the newer ball joints in the 67-72 arms. You just have to use a73-87 spindle.
Old 01-10-2009, 01:57 AM   #7
MonteSS454
MonteSS454's Avatar
But the 73-87 control arm bolts right to the 67-72 frame and spindle or do you have to use a 73-87 spindle because of the ball joint differences?
Old 01-10-2009, 02:06 AM   #8
lowriden58
lowriden58's Avatar
i would imagine you just use the old style ball joints in the newer arms
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 01-10-2009, 03:10 AM   #9
Aarons72s
You got it.
