Old 01-09-2009, 12:25 PM   #1
bbarooo
bbarooo's Avatar
More Brake Troubles
I know there have been alot of brake questions lately but I'm stumped. I did the brakes on a 72 C-10 replacing everything but the rear brake hose and proportioning valve. I could only get a trickle of pressure out of the rear brakes but the pedal felt good so I drove it(with the brake light on). The light went off for a while and came back recently. I checked the fluid and the front brake reservoir was overfull(spit out when I released the cap) and the rear was empty. Anyone had this happen to them?
bbarooo is offline   Reply With Quote
Old 01-09-2009, 12:29 PM   #2
bbarooo
bbarooo's Avatar
Re: More Brake Troubles
I have also since replaced the rear hose and swapped the prop valve with one I knew was good with the same results. No pressure in the rear brakes and no gravity bleed on all 4.
Old 01-09-2009, 12:59 PM   #3
cdowns
cdowns's Avatar
did you clamp the pin on the combination valve like it says to do in the service manual?
Old 01-09-2009, 01:07 PM   #4
nac593
cdowns, could you explain the manual's procedure. I couldn't find it in my book.
nac593 is offline   Reply With Quote
Old 01-09-2009, 03:33 PM   #5
windmill
windmill's Avatar
You need to change the proportion valve. These will go bad on the inside. make sure you get one with disc-manual brakes witch is a 70-30. but if you go disc-disc you will need the 50-50.
72 swb pickup
http://i124.photobucket.com/albums/p...k/100_0958.jpg
1967 chevelle ss
1966 mustang getting a l33 ls motor
1969 chevy dump truck
1989 mustang 6.0 ls best time of 1.29 at 5.91
https://www.youtube.com/watch?v=JtbooZoGZmQ
windmill is offline   Reply With Quote
Old 01-09-2009, 03:41 PM   #6
bbarooo
bbarooo's Avatar
cdowns...I read that in the service manual but I'm not sure where to find that pin or how to clamp it. Any advice?
windmill...I swapped the valve with a functioning 72 and it didn't change anything.(accept to give me another truck with no brakes) And that one bled ok a few months back.
Old 01-09-2009, 04:13 PM   #7
nac593
bbarooo, can you explain what the manual said as far as clamping it?
Old 01-09-2009, 04:56 PM   #8
windmill
windmill's Avatar
Ok i see where you changed it. start from the pportion valve and make sure you have fluid come out their for the rear brakes. if so , go to the next place and check for pressure their.(before the rubber hose) the hose could be bad on the inside.
72 swb pickup
1967 chevelle ss
Old 01-09-2009, 05:36 PM   #9
cdowns
cdowns's Avatar
the pin on the combination valve is normally toward the front/sometimes its covered by a small rubber bulb
i clamp it in place to keep it centered with a cclamp,there is a special GM part#tool to do it tho i've never seen one
Old 01-09-2009, 05:46 PM   #10
70GMCer
70GMCer's Avatar
If the prop valve is stuck, clamping that pin/rubber plunger will not work. I've been told to drive the truck to around 10 or 15 mph and then slam on the brake pedal hard. This will most likely release that valve. You might have to do this a couple times. I didn't know about this until someone on here told 70c10 to try that. Damn if it didn't work. Then bleed the brakes. Also, the dash brake light will stop coming on.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-09-2009, 06:22 PM   #11
bbarooo
bbarooo's Avatar
nac593...the service manual I have only says to clamp it in place using the special tool
windmill...thanks for the voice of reason. The hose is now new as well but the pressure must get lost somewhere. Have you ever worked on something so long you forgot how it works? Yours is a sure way to find it.
70GMCer...thats a good one to try first, I don't even have to get dirty.
Thanks for your help!!
