Old 01-09-2009, 01:42 PM   #1
nac593
how to remove wire back up light?
I got the brake light figured out, but not the back up light. It has a green wire on drivers side. Is there a trick or am I just not seeing something?
nac593 is offline   Reply With Quote
Old 01-09-2009, 02:29 PM   #2
71tahoe
71tahoe's Avatar
Re: how to remove wire back up light?
I can't make sense out of the question. What is it you want to know?
71tahoe is offline   Reply With Quote
Old 01-09-2009, 02:42 PM   #3
nac593
I want to remove the wire that the bulb attaches to. The wire that attaches to the housing that has the lense cover. The brake light wire just unclipped from its housing but not the back up light.
Old 01-09-2009, 02:49 PM   #4
71tahoe
71tahoe's Avatar
I'll go look. I was going to suggest some wire cutters and yank the other end but didn't think that was what you wanted to know.
Old 01-09-2009, 03:06 PM   #5
71tahoe
71tahoe's Avatar
Seems I was right
You'll have to push the connector assy. through, cut the crimped connector and pull the spring and housing off the end. I don't know where you will find another connector to crimp on there when replacing though.
Old 01-09-2009, 03:13 PM   #6
nac593
Thanks for the response. I was looking and looking and just could not figure it out. It seems like there has to be a way to do it. Everything else on the truck is able to come apart, but not this? I was thinking cut it, but would really like to find a way without damaging it.
Old 01-09-2009, 03:19 PM   #7
71tahoe
71tahoe's Avatar
I didn't try this but if the rubber is still pliable, pull the spring out and try to squeeze it trough the hole. There should be some room without the spring in there.
Old 01-09-2009, 03:35 PM   #8
CPNE
Resident Curmudgeon
CPNE's Avatar
Here is the correct method.
1. Remove tailight housing from end of bed.
2. Reach in and grab the light green wire that goes to the backup housing. It should be accessible with the lower tailigh housing removed.
3. Pull it out until you can access the rubber boot that joints the housing's harness to the tailight wiring harness.
4. Separate at that boot by pulling it apart. You may find that after 40 years the rubber is hard and stiff, so you may have to really tug on it.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 01-09-2009, 03:42 PM   #9
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
DO NOT CUT THE WIRE OR TERMINAL!Do what the previous poster said.
There is a weather-tight connecter right behind the taillight housing for the backup light. (Green Wire). Seperate the rubber boots and you are good to yank the B/U light housing.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 01-09-2009, 03:56 PM   #10
nac593
Thanks!
Old 01-09-2009, 04:00 PM   #11
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Don't I know it... Could not figure out how it came apart. Cut the wire, pulled it out and was like Doh! Pulled the connector apart on the other side.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-09-2009, 04:04 PM   #12
nac593
Hey, someone else in san diego. Where abouts are you? Do you know of any good shops or places around that relate to our trucks?
Old 01-09-2009, 04:17 PM   #13
71tahoe
71tahoe's Avatar
nac593, didn't mean to lead you astray. The knowledge available on this board is amazing.
Thanks guys, I learned something new today. (flashback to 5 years old and wondering how that Mickey Mouse phone worked...keyword, "worked")
I haven't gotten that far into my rebuild yet so I can avoid at least one hack into the wiring. The other "hack" will be holding the cutters
Old 01-09-2009, 04:27 PM   #14
nac593
I wouldn't have ever attempted all the things I've done to my truck, without all the people on this site. I learn every time I check it out. Thanks everybody.
