3/4 ton to 1/2 ton.
hello everyone, im new, i have a couple questions, what would be a good axle swap thats 5 lug for my 71 lwb? will they bolt right up? i was thinkin maybe from a 80's model truck? is that one good? thanks for your help.
Re: 3/4 ton to 1/2 ton.
anyone?
Resident of Here
Bump for ya
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
its all about the +6 inches
Do you have coils or leaf spring rear suspention?
Moderator
![]() Join Date: May 2007
I am going to follow this thread, as I am looking at changing a 3/4 ton to a half ton set-up...
if you have coil, then a 71/72 1/2 ton 12 bolt will swap right in.
If you have leaf springs, then you need to locate a rear with the same spring pad width, or start cutting and welding |
ok, that helps, im prayin it has coils... i dont have a welder or cuttin tool, or even access to one.
Moderator
I thought all the 3/4 tons had leafs....guess some have coils too.
#10 | ||
IIRC, coil was standard and leaf was the option on Chevys and the opposite was standard on GMC, with coils being the option. Once you hit the 73-87 generation, the coils are gone, leaf on everything.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() Last edited by LONGHAIR; 01-09-2009 at 07:12 PM. |
Son of a gun
I wish all of you guys would give your 3/4 stuff to me, I want to go from half ton to 3/4!
Bill BEATERS ARE NEATER |
i converted my 72 burb from 3/4 to 1/2 ton, all I did was get a 72 1/2 ton rear end to make it 5 lug then for the front rotors i went with the early classic (ECE) c20 to c10 dropped conversion spindle its made to take all the c20 ball joints etc. but allowing you to use a 5 lug rotors in front.
current project: 1964 chevy II Wagon 1956 3100 1972 c10 burb bagged 1962 GMC burb 1963 c10 burb 1966 c10 burb 1995 chevy lowerado 5/7 static drop daily driver 1963 c10 step side 1965 super sport impala 1967 c30 |
#13 |
Never have been a fan of the 3/4 ton rear axle....you have to remove both axles to do the brakes unless you have swapped over to discs. When you don't have the tools and know how, that can get expensive!!
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
#14 |
my dad has been a mechanic for almost 30 yrs, im sure it wont be that hard for him... will i need to change drive shafts? or just axle, coils, front suspenion, 5 lug conversion, wheels???
#15 | |
Resident of Here
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() Last edited by thirdstreettito; 01-10-2009 at 02:16 AM. |
#16 |
yes, the drive shaft needs replaced or midified.... or a converson U-joint.
#17 |
Between Trucks...
I had a Dana 60 in my '72 -20, don't have to pull the axles on that.
Beat it to fit, Paint it to match... ![]() |
#18 |
Guess I shoulda said 14 bolt. Never had a Dana.
#19 |
edited by mod, again
#20 |
edited by mod
#21 |
i guess you're doing a 2wd?? i'm converting a 70 4x4 and i'm using axles from a 72; dana 44 and 12 bolt rear. 6 lug axles. good luck to you.
1970 Chevy K20 Custom Camper 1996 Chevy Impala SS 2008 Chevy Avalanche LT3 2003 Honda Accord EX 2001 Hewes Redfisher 16 Fighting Lady Yellow Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118 |
#22 |
all u need is a conversion u-joint that converts a c20 to c10. i bought mine at napa. i used my stock c20 driveshaft
#23 |
The Early Chevy Van Man
Not to be a smartass, but I'm just wondering why you want to get rid of your 3/4 ton equipment? Is it so you can run 5 lug rims??
64 Chevy Van 65 GMC Handi-Van 99 2500 silverado 4x4 ext cab |
#24 |
haha no, i wanna make it a 1/2 ton and 5 lug. 5 lug has a better range of wheels, and 1/2 has a better variety of lowering parts... in my opinion.
#25 |
bump.
