01-09-2009, 05:11 PM | #1 |
Resident of Here
How to get bed apart?
Well I am taking my bed apart to bedline it and paint it and install new floor/front panel. The bolts with the round tops, should I just grind ALL of them off? They all just turn in place. Also, does anyone know of a Stainless Steel bed bolt kit? Thanks for all help.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
01-09-2009, 05:14 PM | #2 |
Re: How to get bed apart?
I cut mine from the bottom between the washer and the nut so as not to damage the bed floor. There are a couple you will need a small cutting wheel for. I used my dremel cutter for those. Don't forget there are a couple of spot welds on the top side of the bed floor to the rear pillars.
------------------------------------------------- Jim Garage fillers... 85 Chevy C10 Silverado LWB 07 Nissan Altima 2006 Mini Cooper S |
01-09-2009, 05:17 PM | #3 |
The spot welds are marked in the pic.
01-09-2009, 05:20 PM | #4 |
Resident of Here
Thanks! Any more help also appreciated.
01-09-2009, 06:26 PM | #5 |
Roadtrip!
Tighten them till they break from underneath. If they are spinning already, you can cut a slot for a screwdriver, or weld a nut on top...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
01-09-2009, 06:40 PM | #6 |
01-09-2009, 06:42 PM | #7 |
01-09-2009, 06:47 PM | #8 |
Roadtrip!
Not my first rodeo... Living in the land of rust, you find lots of methods to take things apart. A sawzall is a wonderful thing also.
01-09-2009, 06:49 PM | #9 |
i've just always ground them down with a cutoff wheel
local hardware store should have stainlees bolts for the bed without having to pay shipping
01-09-2009, 07:44 PM | #10 |
Resident of Here
Yeah, but then I have to find out how many I need for each size. Which could take a while. Plus they might cost more at a hardware store.
01-09-2009, 07:50 PM | #11 |
bolts at the store cost pennys on the dollar, u can get a SS bolt for like .40 cent or so depending on the hardness and if u need to know the size just have someone who may have them on hand off measure them for u, that way u dont have to deal with shipping
PROJECT CIRCUIT RIDER |
01-09-2009, 07:52 PM | #12 |
Resident of Here
OK thanks guys.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck Last edited by thirdstreettito; 01-09-2009 at 07:52 PM. |
01-09-2009, 08:39 PM | #13 | |
I also used a cutoff wheel to cut my bolts out of my stepside. Patience and a steady hand and you shouldn't damage the angle strips or bed floor. I bought stainless carraige bolts for mine from a local place. If you're just going to spray over the bolts with bedliner, this may be your cheapest option?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 02-20-2009 at 03:16 AM. |
01-09-2009, 09:04 PM | #14 |
x 3 that's what I did, too.....Tighten them from underneath until they broke off.
01-09-2009, 09:26 PM | #15 |
I drilled mine out from the top, And if you want I have a set of S.S. bolts that I bought from Chevy Duty that I can measure and give you the thread size on, I paid almost 20.00 bucks for them and felt kind of stupid when I figures out the were just carriage bolts, washers and nuts!!
01-09-2009, 09:36 PM | #16 | |
try and get somebody that knows how to count to help you
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 01-09-2009 at 09:42 PM. |
01-10-2009, 01:02 AM | #17 |
LET'S GO RACIN'
You could also put a small tack on them to the bed. I think parts vendors should sell bolt kits.
Daren 04 Chevy Extend cab 2500HD 6.0 Liter 4x4 71 CHEVY 3/4 4X4 402 BB, th400/np205, dana44/eaton ho52 w/4:10-TOY Rip El Jay RIP BOBBO'S MOM |
01-10-2009, 01:46 AM | #18 |
Chevy Truck Addict
I have taken a few apart and have also used an impact wrench to break them off from underneath... You can usually get over 3/4 of them this way and, as far as the rest, I had better luck drilling them out. Drill a 1/8" pilot hole then use a larger bit to drill through the head. I found a cut-off wheel especially hard to get in the corners without doing some damage.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
01-10-2009, 02:05 AM | #19 |
Resident of Here
Tack?
01-10-2009, 04:32 AM | #20 |
72 Cheyenne Super 80 Silverado Blazer 2wd |
01-10-2009, 04:56 AM | #21 |
cwgreen1971
I just had a person on one side with locking pliers and me on the other with a socket. Worked out great.
01-10-2009, 05:56 AM | #22 |
Yea, tack-em down with a thumbtack so they won't turn. JK. Tack weld the bolt to the bed. Twist off the nut from below, then break the tack weld, and pull out the bolthead. Have you seen this? Would these work for ya?
http://67-72chevytrucks.com/vboard/s...d.php?t=312167
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. Last edited by OhioDan; 01-10-2009 at 06:44 AM. |
01-10-2009, 11:59 AM | #23 |
contact tim @ christiansclassics.com He has a sweet stainless steel bolt kit for the bed.It's not cheap,but it has everything you need.And it's packaged and labeled so there's no guessing.
01-10-2009, 12:13 PM | #24 |
Resident of Here
I dont have a welder. I want/need stainless steel, but thanks anyway. The kit isnt on his website. Do you know the price?
01-10-2009, 01:53 PM | #25 |
yea his website does not contain all he has.Just call him up tell him I sent ya.Here's his number.Toll Free: 877.654.2287 Your welcome in advance,Zac
