01-09-2009, 09:57 PM | #1 |
Backspacing
Ok,I think I have decided to go with Torq Thrust II's with 275/60/15's all around on my 72 Long Bed. Anyone know what backspacing I should get? Some have said 3.75, while others have said 4.5. I called Summit Racing where I will be buying the wheels, and they said they have no idea. Anyone have any pictures of that setup on their truck?
01-09-2009, 10:55 PM | #2 |
67-72 parts collector,…
Re: Backspacing
Hawker7,... What do you have planned for your truck?
Lowering it any? Do you have drop spindles? Stock height? 15x8(?) inch wheels? A 275/60-15 is big on the front. Too big if it's lowered. All this stuff play into it. Ever think about running a 15x7 up front and a 15x8 in the rear? Also if you have any pics of your truck,... that might help.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-09-2009 at 10:56 PM. |
01-09-2009, 11:39 PM | #3 |
BlahBlahBlah
Re: Backspacing
Ive got the same issue going...check out this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=322718 |
01-10-2009, 12:45 AM | #4 |
Moderator
Re: Backspacing
Here's mine, 15x8 and the standard 4.5" backspacing. They don't stick out or anything, look great but I want something bigger. For sale (less tires) for $500 plus shipping.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
01-10-2009, 01:05 AM | #5 |
Re: Backspacing
Man Leevon,... that thing is SWEET!
01-10-2009, 01:08 AM | #6 |
Moderator
Re: Backspacing
Thanks lolife, I didn't mean to jack the thread...his truck could look like mine with these very wheels on it though my truck is actually a 10 footer, it's sporting 12 year old paint.
ps-I saw your new shorty, it's sweet. I'll have to stop by sometime when I'm up that way.
01-10-2009, 09:32 AM | #7 | |
Re: Backspacing
I plan on getting 15x8, and the truck is currently stock ride height. I do plan to lower it in the future maybe 2.5 up front, and 4 out back. From other posts I have read, people are running 275's up front with no issues. |
01-10-2009, 10:26 AM | #8 |
Re: Backspacing
from reading some other posts it seems some people say 275's will rub up front, while others say they don't. Anyone running 275/60/15's on 15x8 with 4.5 backspacing all around???
01-10-2009, 01:02 PM | #9 | |
Re: Backspacing
I just think a 275/60 will stick outside the fenders on a lowered truck, and cause rubbing issues. On a stock height truck they will be fine. Remember. The front "track width" on these trucks is wider than the rear track width. My personal preference is a 7" or 8" wheel up front and a 9.5" or 10" wheel in the rear. It compensates for the different track width. (just my opinion)
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-10-2009 at 01:35 PM. |
01-10-2009, 01:27 PM | #10 | |
Re: Backspacing
01-10-2009, 01:33 PM | #11 |
Re: Backspacing
I have a 2"/4" drop with spindles (disc. brakes) and I ran into rubbing issues on the front wheels with 8/15 GM Ralleys. I bought 8/16" TT II's with the back spacing and I forsee no issues. JFYI.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
01-10-2009, 01:35 PM | #12 |
Re: Backspacing
01-10-2009, 01:37 PM | #13 |
BlahBlahBlah
Re: Backspacing
You might check out this other thread I had going also. Check out seetens truck
http://67-72chevytrucks.com/vboard/s...d.php?t=285491 |
01-10-2009, 01:39 PM | #14 |
Re: Backspacing
Yes,... I've had a 275/60 on a stock height truck. Lowered trucks will be different.
Search in the suspension section about wheels rubbing the lower control arms. It's been posted a bunch. Most people buy their wheels and then lower the truck to find out they don't work. If you're going to stay at stock height,... Leevon has the wheels for you!
01-10-2009, 01:39 PM | #15 | |
Re: Backspacing
01-10-2009, 01:50 PM | #16 |
Re: Backspacing
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 01-10-2009 at 01:50 PM. |
01-10-2009, 06:44 PM | #17 |
Moderator
Re: Backspacing
I'm running 3" DJM lower control arms, stock spindles which would explain why I don't have any issues. It's been so long since I lowered it and put those wheels on...clearance might have been the reason I went with the LCA's instead of spindles.
If I remember correctly, there is some light trimming to do on the drop spindles with 15x8 on 4.5" backspacing. I wouldn't want to start grinding on brand new spindles. But my setup works fine, Hawker I sent you a PM with the wheel pics.
01-10-2009, 07:52 PM | #18 |
BlahBlahBlah
Re: Backspacing
LEEVON those tires on your truck are 275 60 15's?
01-11-2009, 01:31 PM | #19 |
Re: Backspacing
what is the factory backspacing?
01-11-2009, 03:24 PM | #20 |
Moderator
Re: Backspacing
You got me thinking...so I double checked the size. Hawker I have to apoligize, I've got 255/60/15 which would explain why I don't have any rubbing issues. My '87 has 275's at stock height.
01-11-2009, 03:35 PM | #21 |
Re: Backspacing
ok, so now will 255/60's work up front with the 4.5 backspacing and 275/60's out back? Is it the tire that rubs, or the wheel?
