01-10-2009, 10:40 AM | #1 |
whats the diffrence
I was looking at buying this 62 c10, but dont know much about them, my question is: what is the diffrence between them and 63 and up as far as the chassis. (i.e. brakes, steering, suspension front and rear. Thanks
01-10-2009, 10:53 AM | #2 |
Re: whats the diffrence
the '60-'62 has a X frame and torsion bars up front. stock suspension parts are spendy, but you can swap in an '73-up cross member.
the '63-'66 and '67-'72 suspensions are pretty much alike, and you can just change to '73-up arms to have disc brakes and updated suspension. And
CHEVY ONLY |
01-10-2009, 11:22 AM | #3 |
Thank you for the info, that's exactly what I wanted to know.
01-10-2009, 12:05 PM | #4 |
Welcome from a fellow hoosier................Hemmit
01-10-2009, 12:26 PM | #5 |
60-62 also have a different rear end, so swaping in a 5 lugger takes some fab work,also if yours is a stick it has a hydrulic clutch that is feed by your master cylinder ( brake/clutch) so when updating your brakes this has to be modified too .
No biggie . Nice truck and welcome from SAN JOSE Nor*Cal
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 01-10-2009 at 12:27 PM. |
01-10-2009, 12:59 PM | #6 | |
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
01-10-2009, 05:32 PM | #7 |
both, the perches are spaced different and the panhard bar is longer . Both are ez fixes if you have a torch and welding skills , both of which I dont lol
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
01-10-2009, 08:04 PM | #8 |
Thought that was it...Thanks
