01-10-2009, 01:52 PM | #1 |
still buypickupparts
battery gauge in the instrument cluster
does the battery gauge in the cluster, does this gauge read volts or amps? and another question is when you turn the Ign. key on, or start mode should you see the charge light,(lamp) in the fuel gauge bottom idiot light come on?
Its Gonna be a Great Day, I woke up this Morning. 72 SWB Fleetside freshly painted. putting a 94 LT1 with 700R4 tranny lowered 4 in the front 6 in the back 81 chevy half ton 350 89 Silverado 4x4 going ta church truck |
01-10-2009, 02:10 PM | #2 |
Old member
Re: battery gauge in the instrument cluster
It's a amp gauge and you want see it move much if any.
Yes it should light up for a second to tell you it's working.
01-10-2009, 02:59 PM | #3 |
Factory guage reads amps, not volts
1997 GMC Sierra Ext 1965 Mustang |
01-10-2009, 06:18 PM | #4 |
its all about the +6 inches
and the light is not supposed to work on a guage equipped truck, only the brake light.
