01-10-2009, 02:24 PM | #1 |
SPID question
Does the SPID contain dealer installed options or only Factory installed options? Looking at a SPID with option number INL210 Auxillary Fuel Tank.
Owner says the truck does not and never did have saddle tanks. |
01-10-2009, 02:29 PM | #2 |
Re: SPID question
I might be wrong but I am under the impression these are only factory installed options. If I am wrong other can chime in.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
01-10-2009, 03:04 PM | #3 |
Re: SPID question
What year is the truck? I think that if it was a 72, GM had started putting aux tanks in, but years prior were farmed out to dealers or the aftermarket. SPID only lists options the vehicle left the factory with.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
01-10-2009, 03:39 PM | #4 |
Resident of Here
Re: SPID question
Is he the original owner?
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
01-10-2009, 03:53 PM | #5 |
Moderator
Re: SPID question
Saddle tanks were a dealer installed item. The 72 factory aux tank has a filler just like the one in the cab and it sits a little further back from it.
01-10-2009, 04:37 PM | #6 |
Gone to greener pastures
Re: SPID question
My '72 GMC has option "NL2--Auxiliary fuel tank" listed on the SPID.
And the filler is a tad over 1' aft of the front of the bed.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
01-10-2009, 04:43 PM | #7 |
Old member
Re: SPID question
Could be a glove box off another truck also. Just a guess. If he say's it never did have them, then I would say it's been swaped.
01-10-2009, 06:16 PM | #8 |
its all about the +6 inches
Re: SPID question
more likely the bed was sapped.
The SPID is only what was installed on the assembly line. Sometimes there were mistakes made, but they were generally pretty acurate |
01-10-2009, 06:48 PM | #9 | |
Re: SPID question
Dealer installed were put there by Colorado Customs out of Brookfield Colorado and there were fuel access doors or filler ports behind the wheel well
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
01-10-2009, 07:05 PM | #10 |
Re: SPID question
72 not original owner. VIN on SPID matches truck. When I get to see the truck I'll see if I can tell if the bed was swapped or tank removed and bed repaired as well as dash repaired where the switch was. I think a bed swap is most likely.
Anybody have a picture of the following: switch location, aux tank location underneath the truck, or any 70-72 medium gold poly truck, paint code 526? |
01-10-2009, 07:09 PM | #11 |
Re: SPID question
As said by 71 super,the only actory installed auxilary tanks are the left side tanks in`72.
01-10-2009, 07:12 PM | #12 | |
Re: SPID question
There is a "double valve" on the floor, between the seat & the driver's door that switches the fuel flow from 1 tank to the other. The reason I say "double valve" is, 1 part of the valve switches the gas from the tank to the fuel pump & the other part switches the fuel pump return line.
