3/4 ton lift spindles?
Does anyone know if there are Lift spindles available for 3/4 ton 2wd (C-20) trucks? I have found drop spindles, but it is going to be $$ to lower the truck, which requires a lot more work and parts. So, I figured if I lift the front end of the truck, it will be even with the rear end, and I can keep the 33" tires on it, and go with a lifted truck as opposed to a lowered one. No need to change the 8 lugs or any of that mess. I checked Fabtech, and it looks like they do not make them....any one know of a manufacturer?? Thanks.
