Old 01-10-2009, 05:42 PM   #1
Zonaman
Zonaman's Avatar
Little speaker wiring help
I'm putting a OE am radio back in the dash. I've got 4 speaker wires from the speakers (a + and - on each) and one plug for speakers on the radio. How do I wire those up to get sound from both speakers?
Thanks!
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 01-10-2009, 07:20 PM   #2
Andy4639
Old member
Andy4639's Avatar
Re: Little speaker wiring help
I'm going to take a guess and say both + of speakers to the + of radio and both - of speakers to - of radio. With that being said are the speakers the right Ohms for the radio?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-11-2009, 02:41 PM   #3
Zonaman
Zonaman's Avatar
My speakers are only 4 ohm. Decided to go with a single 8 ohm speaker I have. I'm still a bit confused. Is the ground terminal on the radio for the - wire of the speaker and the power termianl for the + speaker wire?
Old 01-11-2009, 02:54 PM   #4
Andy4639
Old member
Andy4639's Avatar
Like I said before I'm guessing because it's a factory hook up and I haven't seen one in about 10 years. Sorry could be any more help. You may want to post it in the audio section also.
