Old 01-11-2009, 02:56 PM   #1
txstbobcat
exhaust donut and bolts
Perplexed here...
I am putting a new donut on the exhaust manifold and it seems like the bolts are now about 1/8" too short. The nuts will not catch.
Any advice other than replace the studs? and if that's the answer, how do i get them out after 45 years of being on there?
txstbobcat is offline   Reply With Quote
Old 01-11-2009, 11:30 PM   #2
62 short step
62 short step's Avatar
Re: exhaust donut and bolts
Do you have any pics? Are you sure its the right gaskets?
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 01-12-2009, 01:47 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
How about clamping them to get the nuts started? C-clamp or vice grip; something?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-12-2009, 05:21 PM   #4
MacAttack
283 Drama Queen
MacAttack's Avatar
May be easier to remove the exhaust manifolds.
Heating the ends of the manifolds up with a propane torch (if you’ve got the clearance to do so) and then melting a candle on the top of the bolt thru-holes (if they do go through) may work.
The wax will penetrate and might break the bolts loose.
I’ve done this on some manifolds before to get the studs out, but always out of the vehicle because of the fire hazard. If you try to double-nut these things off with just some sort of spray penetrant to break the studs loose, you’ll usually just snap them off - especially if they’re eroded from all the heat over the years.
Good Luck.
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 01-12-2009, 10:28 PM   #5
txstbobcat
its the gasket that came with the gasket set. i went to the parts store to check and they came out with the exact same one.
i tried the clamp thing.... didn't work....
i soaked it with penetrating oil tonite...see what happens tomorrow.
