Old 01-11-2009, 07:41 PM   #1
4DSEVEN
4DSEVEN's Avatar
What tire & rim size are you running for a 3100
Hi everyone, I just purchased a 47' and am looking at tire options.
Just getting into this and next week the roof is being chopped and a camaro clip installed from a professional shop.
I am not planning to bag the truck, just want a nice low ride.
The fellow that is doing the chop owns this truck (pic) and this is the stance I am looking for.
I will post pic's of my progress as it moves along.
Looking for tire ideas please.
[IMG][/IMG]
4DSEVEN is offline   Reply With Quote
Old 01-11-2009, 07:53 PM   #2
aintmisbehavinn
Re: What tire & rim size are you running for a 3100
Nice, I really like that....
aintmisbehavinn is offline   Reply With Quote
Old 01-11-2009, 10:07 PM   #3
50adrod
50adrod's Avatar
I am running 17x10 rear and 17x8 fronts, 315/35's rear and 275/40's up front.
mine is not finished yet. if you are not bagging it you will need to stay with smaller diameter rims to keep it low
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 01-13-2009, 03:10 PM   #4
kustombrad
kustombrad's Avatar
I went old school 15" wheels on mine. 15x10 and 15x6 on 275/60 and 205/60 tires...http://67-72chevytrucks.com/vboard/s...d.php?t=320546
kustombrad is offline   Reply With Quote
Old 01-14-2009, 10:18 AM   #5
solidaxel
solidaxel's Avatar
I think I would get some more comments on the Camaro front suspension,
If yours is a 5 window look for the corner glass before you do the chop!
just my $.01, (hard times)!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-14-2009, 11:13 AM   #6
4DSEVEN
4DSEVEN's Avatar
Thanks for the heads up.
I have a mustang clip available also but I am told the Camaro is preferred in terms of larger brake options? I also believe that the camaro front end will handle the weight better although I will not be using the truck for anything other than weekend cruising so I suppose it may not matter...
The window was an issue for the guy doing it on his. What he ended up doing was buying some type of plexiglass and took the original glass with the plexi and warmed it in his oven so it contoured to the exact shape. Once it moulded to the concave, he took clothes pins and let it cool. A bit of trimming and it was complete.
I plan to do the same.
