Old 01-11-2009, 09:27 PM   #1
jdmathes074
got a ls1 guage question for yall.
i am currently in the process of getting all the parts together to do an ls1 install on my 86. ive seen somewhere that someone used guages out of a 90-91 model suburban but i cant find it anymore. im trying to not spend the money on the dakota digital guages. any helpful information (if its possible, worth it, part numbers, etc.) would be greatly appreciated.
jdmathes074 is offline   Reply With Quote
Old 01-11-2009, 09:36 PM   #2
andrewmp6
Re: got a ls1 guage question for yall.
If they are Electric gauges it will work or use aftermarket gauges in it.
andrewmp6 is offline   Reply With Quote
Old 01-12-2009, 07:47 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
You want a 87-91 Cluster with the VSS. You will still need a buffer for it as the signal isn't the same.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-12-2009, 08:37 PM   #4
pcmcobra
pcmcobra's Avatar
my 91 cluster works fine on my 86, as for buffer...I don't know,(maybe u can enlighten us Kris) my cluster only plugs in one way, I spliced my vss wire into connector behind cluster.
Working fine.
I know my speed is not correct right now, as soon as I get new rear done, I'll get the speedo setup, hopefully through my local tuner.
I would like to know more about this "buffer".
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
