Old 01-11-2009, 09:29 PM   #1
texastrendz
mounting brackets for electric valves
just wondering if anyone can post pictures of how you mount the solenoid valves for the air ride suspension. can not find any pics thru the search feature, any help would be great guys. as always thanks again.
texastrendz is offline   Reply With Quote
Old 01-11-2009, 09:29 PM   #2
texastrendz
Old 01-11-2009, 09:41 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: mounting brackets for electric valves
Here's the set up on my 77 Cheyenne
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-11-2009, 09:48 PM   #4
texastrendz
that looks like the way to go for a manifold, the only problem is that i am running the gc extreme valves, manifolds are a cleaner look, but i came across these valves on a good deal. need pics of valves like that if anyone has one, thanks again.
Old 01-12-2009, 10:26 AM   #5
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Mine are mounted to the inside of the frame rail in 4 different spots. It's hard to see the bracket, but basically I used some u-bolts from TSC, welded the flanges they came to a piece of 1/8 steel that was bent at 90 degrees (two per each dump/fill) and bolted everything together. I like this method better than using the bolts that are meant to hold the spools together - it's much studier.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 01-12-2009, 11:55 AM   #6
project 67 sub
project 67 sub's Avatar
nice install
Originally Posted by smashingchuck View Post
Mine are mounted to the inside of the frame rail in 4 different spots. It's hard to see the bracket, but basically I used some u-bolts from TSC, welded the flanges they came to a piece of 1/8 steel that was bent at 90 degrees (three per each dump/fill) and bolted everything together. I like this method better than using the bolts that are meant to hold the spools together - it's much studier.
project 67 sub is offline   Reply With Quote
Old 01-12-2009, 03:59 PM   #7
Twisted Minis
Twisted Minis's Avatar
I use ASCO valves, and carry brackets for them. It's hard to see them here, but they are a nice easy way to mount the valves.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 01-12-2009, 06:06 PM   #8
Shane
Shane's Avatar
my SMC valves came with brackets ... sorry, no pics currently though
Shane is offline   Reply With Quote
Old 01-12-2009, 09:09 PM   #9
jlaird
jlaird's Avatar
mine:
jlaird is offline   Reply With Quote
