Old 01-11-2009, 09:56 PM   #1
texastrendz
question about porterbuilt dropmember
if you order a porterbuilt drop member does it come ready for the motor. everyone says it is a bolt in unit. do you have to weld the tabs in for the motor mounts or they already installed. thanks guys
texastrendz is offline   Reply With Quote
Old 01-11-2009, 09:59 PM   #2
stunna
Re: question about porterbuilt dropmember
the tabs are already welded on, the unit requires no welding at all.
stunna is offline   Reply With Quote
Old 01-11-2009, 10:24 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
The only welding would be for the notch for the rack steering/tie rods to clear the frame.
Give Nathan Porter (porterbuilt) a shout by Pm'ing him directly.
Keith
Convert to disc brakes.
Old 01-12-2009, 12:35 AM   #4
PBFAB.COM
PBFAB.COM's Avatar
As mentioned, there is no welding required on the Dropmember itself. The only welding required it in regards to the notches in the frame for rack and pinion clearance.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
