Old 01-11-2009, 11:55 PM   #1
Pont406
Lines for disc brakes conversion.
I am almost done collecting parts for the front. In 2 weeks I will order axles and powertrax for the rear. I know that brake lines on a 69 c10 will not match with brake hoses. Inline tube wants $160 for a conversion lines which I think is too much. Where did you guys get brake lines? Junkyard or bend your own?
Pont406 is offline   Reply With Quote
Old 01-12-2009, 06:47 AM   #2
JimKshortstep4x4
Re: Lines for disc brakes conversion.
I bend my own brake lines and since the front disc lines are 3/16" it is very easy to make them up.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-12-2009, 10:17 AM   #3
thirdstreettito
Resident of Here
thirdstreettito's Avatar
How do you bend em? Where do you buy em?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-12-2009, 11:41 AM   #4
Elephanthead
I need to replace the line that goes to the passenger front cylinder, the damn thing is got a arch in it to run along the cross member, I don't see how I am going to match that dang thing. I am going to try and get it close and call it a day. Are the generic 5 buck benders good enough, or should I spring for a more expensive bender?
Elephanthead is offline   Reply With Quote
