Old 01-11-2009, 11:56 PM   #1
SactoJim
SactoJim's Avatar
Driveshaft question....
Weather was beautiful this weekend and had my truck out for a bit and noticed a small vibration that progressively got worse....long story short, almost made it back to the shop before the front U joint gave out!
After getting trailer and going through all that BS, only had time to get it up in the air for a quick look. Think I'm gonna have to replace the drive shaft.....pretty beat up.
So the question.......guys with 700R4 / small block combos. Driveshafts from anything else out there close to the correct size? Be nice if I didn't have to have one made or buy a long one and have it shortened.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 01-12-2009, 04:09 AM   #2
sleepertruck72
sleepertruck72's Avatar
Re: Driveshaft question....
I dont know about a shortbed, but my longbed C-20 has 350/700r4 and I took the stock driveshaft to get shortened at a shop. Mine is a 2 piece driveshaft and I had one cut and rebalanced(dont remember which one was cut, shorter or longer one) and they installed a new carrier bearing. The tranny was a TH350 and the splines are the same.
I am interested to see if any other years would work just to learn something today
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 01-12-2009, 09:27 PM   #3
SactoJim
SactoJim's Avatar
TTT........FYI...
Driveshaft measure's 56 3/8" from centerline to centerline of U-joint.
Any help appreciated......just looking for info on what other drive shafts may be out there in other types of vehicles that would be either long enough or too long so I could start looking.
If that don't work, gonna have to have one made.....thx!
- supercharged 383
- 4 wheel discs
My Build Thread
Old 01-12-2009, 09:42 PM   #4
bobbo
Droppin' It Like It's Hot!
bobbo's Avatar
I would be interested in this too, I am running a 700r4 with the stock 2 piece driveshaft. It works good, but I eat up carrier bearings like crazy. I bought an 85 chevy for the front brake stuff and pulled the driveshaft out but it is too long, I am considering having it shortened but what issues would there be with the crossmember, if any? I do have the truck lowered quite a bit front and back, how important is the angle of the shaft in relation to trans/diff? Not to steal your thread SactoJim, just curious as well.
Robert
Life Member
RIP CAROL JANICE HARTMAN. BELOVED MOTHER. 01/04/53 - 03/05/09
1969 1500
Norwood, MO 2007
Big Sandy, TN 2008 Had nothing to do with the forklift!
Kirkwood, MO (Midwest Meet 2009)
Midwest All Truck Nationals, KCMO - 2008 - 2009 - 2010 - 2012 - 2014
SUPPORT THE SITE HERE!
bobbo is offline   Reply With Quote
Old 01-12-2009, 09:57 PM   #5
EyeH8the24
EyeH8the24's Avatar
we used the front part of a lwb straight 6 3 speed .....and the rear part of another lwb shaft only because original rear shaft had been dropped and chewed up....it worked out great .so guess its a straight 6 3 speed shaft that worked for me ,the 350 is in the stock 350 location for motor mounts to
EyeH8the24 is offline   Reply With Quote
Old 01-12-2009, 10:04 PM   #6
Painter D
Painter D's Avatar
I wish I knew of one, I would have gone that route.
I had to have one made.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 01-12-2009, 10:11 PM   #7
71 super
71 super's Avatar
Might check a shaft out of mid 70's caprice car, they are around the 56 measurement I believe. In yards around here they pull shafts and pile them in backs of trucks, I have taken a tape and pulled until I found the right length with a GM yoke- there are a ton of 350 shafts out there, so this may be an option. Check with the Caprice first, then if needed plan "B".
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 01-12-2009, 10:25 PM   #8
LEEVON
Moderator
LEEVON's Avatar
Sacto,
I swapped a 700R4 into my '87 and I recall when doing research that some folks said the 88-up pickups with 700R4/2wd have a driveshaft length of 56 3/4".
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-12-2009, 10:36 PM   #9
SactoJim
SactoJim's Avatar
Good places to start looking......thanks guys!
Originally Posted by LEEVON View Post
Sacto,
- supercharged 383
- 4 wheel discs
My Build Thread
Old 01-14-2009, 12:34 AM   #10
70clone
70clone's Avatar
i just did the conversion i used a 1993 chevrolet 1500 with the 7oor4 driveshaft. fit perfect the seal line on the yoke matched up like it was made for it the only thing you will need is a cross jointthat will go from the wider driveshaft the the smaller rearend yoke. your local driveshaft shop will have the crossjoint you will have to get rid of the carrier bearing mount if your truck is lowered going to a one piece driveshaft gets rid of the ****ty carrier bearing. the truck has to be a 1993 i tried just about everything else i know 1993 works perfect
70clone is offline   Reply With Quote
