01-12-2009, 02:53 PM | #1 |
Rear diff cover from Jegs
I bought the Jegs read differential cover part# 720-9895 for my 12 bolt. The chrome bolts that came with it are to long, i.e. they bottom out. Jegs can’t find any thing shorter to send me. Do I have something odd? Any ideal as to what’s up with this? Thanks.
01-12-2009, 07:17 PM | #2 |
Active Member
Re: Rear diff cover from Jegs
I have no idea how Mr.gasket sized your bolts - run the the local hardware and buy some washer head bolts that are serrated on the heads - they should be zinc plated silver and should work fine for you
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
01-12-2009, 08:17 PM | #3 |
Watch out for your cornhole !
I'd just use a sander or bench grinder to knock a little off of the length.
01-12-2009, 08:19 PM | #4 |
make sure there isnt any gasket material/sealer in the threads.. this could also cause it.
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 http://i195.photobucket.com/albums/z...en58/001-2.jpg |
01-12-2009, 08:54 PM | #5 |
I had the same problem from LMC rear Diff Cover. I just used the old Bolts
1970 Jimmy 4x4 IL6 1971 Jimmy 4x4 350ci v8 1971 SWB 327ci v8 1972 Short Stepside 305ci v8 1972 Blazer 2WD CST LS9 350ci 4sp 1999 4 Door LB 1 Ton Old Body Style 5.7 v8 |
01-12-2009, 09:05 PM | #6 |
I'm with TX Firefighter. Trim off a few rounds of threads off the end of the bolts. Or pick up some correct length Stainless bolts and polish up the heads a bit.
01-12-2009, 10:06 PM | #7 |
Use a vice and a bandsaw or manual one.
1968 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=321717 1959 Chevy Apache 3100 SWB Big Window http://67-72chevytrucks.com/vboard/s...d.php?t=597069 |
