56 4x4 conversion
Working on a 56 GMC . Need help. Want to upgrade the chassis and convert to a 4x4. What would be a good year chassis to start with ? Thanks.
![]() Join Date: Nov 2008
Re: 56 4x4 conversion
Mine had Jeep pickup (J20), axles, transfer and steering gearbox grafted on to my stock frame.
Brandon 63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne 57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380 72 K20 Long bed stepside (wife's) 72 K20 Long bed 396 (flip or keep...?) The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476 |
I assume you're wanting to use a solid front rather than the newer IFS? I don't think there's a Chevy solid front axle that is narrow enough to even come close to staying inside the fenders. The rear of my '77 K-5 is 61" between wheel mounting surfaces and the front is about 4" wider. Try over at http://www.pirate4x4.com/welcome1.php, there's a lot of good info on there for several different brands. Good luck, a '56 4x4 will make for a badass truck. You might also try to find out what front GM used for the NAPCO 4x4's.
I kept the stock frame and springs and used 74 axles, steering, trans and transfer case. Look at my build thread "Lurker Orrie" http://67-72chevytrucks.com/vboard/s...d.php?t=233305. Also there are some builds in the 4x4 section. I have a friend that is putting them on shortened early 90's 4wd dually frames too. Welcome...
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
56 on 80 short 4x4 frame - Page 2 - The 1947 - Present Chevrolet ...Page 2- 56 on 80 short 4x4 frame The 1947 - 1959 Chevrolet & GMC Pickups Message Board.
67-72chevytrucks.com/vboard/showthread.php?t=290391&page=2 |
also checkout page 1 of my thread
Thanks for all of the info. Great site Have a question for Gene. Your truck looks great , it is exactly what I would like to do . Was the frame from a pick up or a Blazer? I read that you had to move the fire wall back 2 inches. Was that just at the bottom or the whole thing? Thanks again.
The frame on this one was an 80 short bed 4x4 frame it is approx 1'' longer than the frame on a 56 short bed and same width in back
The beds are pretty much the same just different back fenders I had to move the firewall back a couple of inches to clear dist when using stock 80 model motor mounts Would be best to move center section back a couple of inches most of way up and down clears well everywehre else Gene Last edited by Gene Sharp; 01-13-2009 at 02:45 PM. Reason: spelling |
