Old 01-13-2009, 02:13 AM   #1
LuckyHenriksen
LuckyHenriksen's Avatar
Under Bed Tank Install
So I just got my FCG alum. fuel cell, and its awesome! But I need help..... I know this topic has been covered alot, but I couldn't find the answers I was looking for in a search...... once I figure out where it bolts up in the frame, what is the best way to cut a filler hole? It will be straight through the floor of the bed, and I don't plan to have any fancy cover welded on or anything. Do I have to cut a big enough hole to get my whole hand in there and open the cap? Or can I make it extend out enough to where I can just pop a cap off up top. I don't know what to do!
Heres what my filler looks like
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 01-13-2009, 11:21 AM   #2
LuckyHenriksen
Re: Under Bed Tank Install
33 People have looked and no one has any advice.....
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 01-13-2009, 12:08 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
This choice is, OF COURSE, yours to make. I have seen many filler holes in the bed and most of them use one of the aluminum filler covers that is made for the sides of the late model trucks. The owners route out the wood and set the cover down into the floor. If the bed is not wooden, then they make a round hole to bolt it to and then it sets slightly higher than the floor. I have deep dark thoughts of it getting caught on something sliding around in my bad, so I personally would inset the filler cover some. I have also seen many use the sheet metal covers from a later truck that is blended to the floor and it just opens like it would on the bedside.
As for the hole size, if you want a small hole, then make it so, but make it so that you can get the cap off without going into a tool box for a pair of waterpump pliers everytime. I also had a friend put his filler in the bed's rear stake pocket and run the fill tube under the bed to the side and then turn up through the bed's body work.
Look for the fill hole in the wood bed that is in the pictures.
piecesparts is offline   Reply With Quote
Old 01-13-2009, 03:38 PM   #4
project 67 sub
project 67 sub's Avatar
looks like its at the very bottom of the pic in the center wood plank
project 67 sub is offline   Reply With Quote
Old 01-13-2009, 03:52 PM   #5
my67chevytruck
Under Construction
my67chevytruck's Avatar
I have one of these on my '56 and probably do something similar on my sons:
http://www.discountmarinesupplies.co...&product=86661
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-13-2009, 05:35 PM   #6
Mudder
Mudder's Avatar
I like this one and you dont't need to remove the cap to put gas in it.
Mudder is offline   Reply With Quote
Old 01-13-2009, 07:05 PM   #7
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Stake pocket filler!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-13-2009, 09:56 PM   #8
piecesparts
You are right about the filler in the wood bed--it is at the bottom of the picture. It is made of the same wood and almost disappears, when covered.
Attached is the picture of a 71 with the filler in the stake pocket. They used an Arlen Ness motorcycle gas tank filler. You push down on it and it pops up and then you can unscrew it.
Old 01-13-2009, 10:10 PM   #9
Gray Ghost
Gray Ghost's Avatar
I really like that stake pocket filler!
On the wood bed with the inlays...too bad the pic doesn't show the whole filler...that's a nice piece of work!
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 01-13-2009, 10:16 PM   #10
LuckyHenriksen
Hey thanks for the replies guys. I like the idea of that marine filler, it looks good. Can I attach that to my fill tube so that I just open the top to fill?
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 01-13-2009, 10:19 PM   #11
piecesparts
Here you go. This is in a 66 Chevy truck.
Old 01-13-2009, 10:23 PM   #12
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
piecesparts,
that ones so hidden id set there for a couple minutes everytime i pumped gas lol
John
1999 Toyota Tacoma 4x4
Old 01-13-2009, 11:48 PM   #13
LuckyHenriksen
I wonder how long it takes to fill trying to keep that wood nice.
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 01-13-2009, 11:49 PM   #14
LuckyHenriksen
What vehicle is that push through cap off of?
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 01-14-2009, 12:07 AM   #15
Mudder
Mudder's Avatar
It was in the back of a 30's something street rod truck. He told me he got the whole deal from a street rodders place for parts.
Old 01-14-2009, 12:19 AM   #16
phipp13
THE DAMN YANKEE
phipp13's Avatar
hey Lucky, have i got a deal for you!!! almost too good to be true!! if you need a patch for the hole in the cab left by the old tank, please check out this thread here is the link. Respectfully Phipp13
http://67-72chevytrucks.com/vboard/s...d.php?t=319383
phipp13 is offline   Reply With Quote
Old 01-14-2009, 12:24 AM   #17
LuckyHenriksen
Hey phipp thanks for the offer, but I used Shiftys method of bolting the OG gas cap on with a carriage bolt.
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
