Thought I would join the crowd and start a build thread, although it actually wont be an entire build thread as I already have a good body and interior, more of a frame build for the rest the parts. I am in the process of building a sled pulling truck that I can still drive on the weekends. Any input from current or past pullers is more than welcome as this is all new to me.
Completed: Axles: Dana 60 front, 4.56 gears and a full spool, with crossover and high steer 14 bolt rear with 4.56 gears and a Detroit Locker Suspension: 6 EZ Ride front springs with a 1 zero rate block and 6 degreee shim 6 Rear springs with rolled spring perches Bilstein 7100 remote reservoir shocks at all four corners Hitch: Reese hitch with added 2 tubing for additional bracing In Progress: Traction Bars : 2 .25 wall DOM pipe with 1 heims on each end (Have all the material just need to weld up) Suspension Blocks: Need to come up with a design Frame: In the process of boxing from the transfer case back Motor Mounts: looking for an aftermarket crossmember??? Front hitch for weight bracket: Need a design Goals are for all the welding on the frame to be completed by the end of Jan. so it can get powdercoated. Want to have entire truck back on the road by April!!! Have a lot more to add just not the time right now ..need to get back to work
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio ..... 1971 CREWMAX Build.....at body shop for couple more years ![]() |
![]() Join Date: Feb 2001
Re: Part Time Pulling Truck Build
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
